Topping TP20 tripath 2020 amplifier (versus NAD C320BEE)
NEW 2011 Tripath Class T Amp TA2020 Amplifier +12V PSU | eBay
for hasslefree start !
Arjen kits : are gold ..excellent but
making cabinet : real pain
making PSU : same
Linear PSU may damage the chip unless regulated due to mains fluctuations, it did to me
The arjen pre is basic buffer like enhances the high freq response by a small amount , i will say its optional for new comer.
making PSU : same
Thanks kaushik. Is the S.M.S.L SA-36A superior than other makes?
Shray
making PSU : same
I have a slightly different take on this. Just get the following and put it in the simplest box you can find, if you do not care about how it looks. Besides you could always change the case later on. All the DIY that would be needed on this would be to hook-up the RCA to the pre, the pre to the amp board and the amp board to the binding posts. Even the simplest electronics technician would be able to help you with this... :)
MKIII Tripath TA2020 PCB 25watt Class-T amplifier SET | eBay
MKIV Universal Pre-amp Uses all double triode 9 pins valves! 14~30V input | eBay
12V 12.5A MEANWELL Switch mode power supply ORIGINAL | eBay
+1 to this.
Sachin
Thanks for your input grubyhalo. The website says "Very large supply voltage range 14-30V!! use with your TA2020 or STA508 on the same power supply!" Will it run from the same power supply? Will the pre-amp run from the same smps?
I don't know if my last question makes sense. I'm a newbie.
Cheers.
I'm no expert by any means or measure but I read up quite a bit on things that interest me. That said, going by the description for the items, you should be able to use the same SMPS for both the pre and the amp modules. All the best for your build! :)
you are correct ..
but I do care about looks people likeme ( many newbies too) the cabinet issue starts .Hooking rca switch etc to a iron box or plastic can be a rough option .consider these i some cases iron cheap boxes will be rusty,paint will peeling,manually drilled cut aluminum boxes will make amp look like school project,getting good finish is really tough.
, many of the technicians will mishandle the kit (many cases i heard people have come to me for help )
options newcomers can choose are
A)Hasslefree Start :
click on S.M.S.L SA-36Aand but the amp, after arrival start listening ~2000Rs
or ,
Muse TA2020 : excellent value ,tested by FM
or
Topping TP20:excellent value ,tested by FM
A wow looking AMP for initial setup
After a while add a SSP(preamp,get the kit from the FM),some one test it.
B)little costly start but good :
*buy soldering/wire/flux n supplies
*buy list by gruby ,the list is good just add a 0-24V power supply, i have tested the whole set it is excellent buy..but yup investment goes to 10k or 12 k with express shipping.
*bend Aluminum/paint old cabbie/get cabiie from VCD player,fit wood
end product :good sounding amp just looks is 3 out of 10.
C)Lowcost but time and effort:
Buy Helder MKII kit ,procure others add a linear PSU with ei core trafo.
I did this!! in <5K you have a very good amp ready running.
a)make sure you keep a regulated PSU .keeping voltage approx 12V or run from some protection device like stabilizer.
12v regulator can be made with power mosfet+LM317 :like this LM317 High Current Voltage Regulator - Electric Circuit
or ,
b)Buy 12V 3A SMPS from ebay india
It is individual choice
or ,
or
I am a total newcomer looking for a hassle free start with help from you all :). There are a few option listed for TA2020 amps. Which one would you all recommend of the ones below based on their components?
Thanks!
[1] SMSL SA 36
[2] Indeed Tripath TA2020
Indeed Tripath TA2020 Cute Class T Mini Amplifier 20WX2 | eBay
[3] Topping TP-20 MK2
TOPPING TP-20 Mark-II 223W 4? Class-T Amp TA-2020 Hi-Fi Digital Power Amplifier | eBay
[4] 2012 Indeed Class T Amp Tripath TA2021
NEW 2012 Indeed Class T Amp Tripath TA2021 25WX2 Stereo Amplifier + 12V5A Power | eBay
[1] < [2] < [3] < [arjen helder 2020 MKII] < [arjen helder 2020 MKIII] < [4]
Please note that 4 has more flat and natural response than all of above still it will has more RF leakage. Both of these pro and cons are due air core output coils.
Please 4 has more flat and natural response than all of above still it will has more RF leakage. Both of these pro and cons are due air core output coils.
Whar does "RF leakage " mean in lay man's language... Please can you help us know. Thanks
Thanks! Also note that [4] is TA2021 and not TA2020 chip. Have anyone tried both and felt any difference between the 2 chips?
Cheers!
These are switching amps which generate internal switching frequency (similar to CPU clock) which is used for amplification along with input audio. This switching frequency is removed at the output of amplifier which leaves back amplified audio only.
This removal is done by coils and some caps at the output. Removal is perfect in toroidal coils as its magnetic field is completed within circular core. For cylindrical and air-core coils magnetic field is radiated in air, acquired by nearby PCB tracks as well as other components. Even that can go outside amp and affect sources like radio. This is RF leakage of output coils.
Most dealers can import and give a good deal on Topping like 3k or so ,
My suspicion is that they may loose the AVR or EXPensive AMP buyers so no one is importing it even if the demand is high.
The dealers already have invested in expensive AV amps that are in stock , but the topping happily serves new audiophiles so every month they may loose say 20buyers of AVR or STEREO amps of Min MRP 15k
Is there any difference between Toping and Indeed amp? When i compare both have the same spec sheet. Look and finish is also same. Yet Indeed sells at a less price compared to Toping.
so whats next after tp20. has anyone done an upgrade yet. something with a bit more power and better sq.
Can someone tell me how do i buy one of these babies from Ebay international. They seem to need a paypal account. I only have Indian Credit/Debit card.
