Toshiba P2305 39" Review
Not sure if this is what you wanted. As for the procedure I have no clue since I wasn't present during the mounting. Anyways I'm back on this forum after a long time and here to thank you for your review. I made the right choice by buying this TV. [emoji2][/QUOTE]
Thanks buddy. That almost cleared my doubts. Are you able to reach those two bolts at the bottom which secure TV bracket to wall mount?
Yeah but my forearms are pretty small in size. One with huge forearms may find it difficult though. I suggest you use HDMI 1 for your stb as its on the back side. [emoji6]
Sorry buddy. Still a bit confused. Does it look like this? I still cannot figure out how to fasten/loosen those bolts once mounted on wall :(
Are you trying to do it yourself? [emoji14] TBH you should live it to a professional rather than risking by doing it yourself. You should get it done by the Toshiba service guy even if it is going to cost you extra. I cannot confirm whether it looks like that as I have said before I was not present at the time of mounting. If you have done this before and have succeeded as well then go ahead and do it.
Once you have the backplate on the wall, you hang the TV on to it. After that use a Longish screw driver and tighten the screws from under tv.
