Aquarian09
Boss, 7010 seems tobe 2.0L+.... I'll check this but don't know if I'll go with it.
Hehe
Didn't realize about the price
Well , just check with them anyways
What's ur budget for AVR ?
Around 50K or so...
Kiran,
You may have already discussed this with your architect, but let me put it out here.
Plan for proper power distribution.
5/15A circuits for AV equipment - 2 circuits
15A circuit for AC - 1 circuit
Try and get dedicated MCBs for 5/15A circuits installed in the HT room itself if feasible.
Raghu
Kiran,
Kiran,
My 2 paise.
Focus on the room/wiring and initial treatment etc. This is going to put a dent in budget and it cannot be delayed. Make sure the wiring is as flexible as possible up to 9.x.y or 11.x.y if feasible. Make sure your contractor keeps power and audio wires in separate lanes/conduits.
Consider using something like these specially for speaker wiring.
Audio/Video Keystone Jacks - Monoprice.com
Raghu,Any suggestions on how many and what colors would i need for 9.2.4 setup? As suggested by the gurus, I'll plan the wiring done for 9.2.4. Thanks!
Good start Kiran :clapping:
When you are saying colors ..... u mean wire colors ?
use Imgur: The most awesome images on the Internet to upload pics and u will get a "Direct Link" of the image uploaded, copy that link, and while posting here ..... click on Insert Image icon and paste that link and submit .... we will get the full size image
Basically u will get all types of links to post ur image in any forums .... copy them and post here
Aditya
Sure Aditya.. will keep updating the progress... the question was regarding the link that Raghu shared on Audio/Video Keystone Jacks...
Are Monoprice wires available in India?
As far as wire goes, in theory there is no special stuff in this simple element. Just low resistance copper (as pure as possible) and insulated cladding. So there are many options, some are:
1. Expensive esoteric speaker wire - high cost and don't know about in-wall uasge
2. Affordable speaker wire - if you can source it in India or for US; Finolex/Monoprice/Bluejeans are some sellers with reasonable pricing
3. Plain old electrical wire - cheapest option; Finolex is very good
Finolex makes speaker wire with thickness up to 14AWG or 2 sq. mm; this seems good enough for the run in your case. Length matching is built-in. Check for in wall capability
If using Finolex electrical wire, you can go to 12 AWG or 2.6 sq. mm
One Red and one black spool may be enough; each spool is 90m and costs about 1.6K
Length matching is your responsibility. Within pair, length match to within 2 - 3 inches. Between pairs, say FL and FR, length match to within 8 - 12 inches.
2. Electronics (AV Rack) will consume 3' x 4', including wiggle room for mobility to connect/disconnect wires and air circulation.
3. Let's assume you place this on the 18ft back wall (one with the door); Majority of power points should be here.
6. Assume the first seating row is about 9-10ft from screen. I guess this is the comfortable distance. Others FMs can confirm.
7. You are kind enough to allow others to share the HT experience. Assume 2 seating rows with 4 seats per row if going with plush sofas/recliners/love-seats. Family definitely, friends selectively; neighbors, well ....
3. You need not run the wires in wall or ceiling. Since it is a dedicated HT room, you may choose to run it along the floor/wall edge with some kind of cable cover or inexpensive cable management solution. This allows for easy cable replacements if and when required.
