okay.
then avr is good for your case than int amp.
follow the previous mail to start with a 50k budget.
also can you confirm do your media plyer have bitstreaming capability..check audio settings...
anyway if dont have a problem to buy used gear can try the onkyo tx747(non hdmi) at 7.5k only..
it dont have hdmi but do have coax and optical.....so pretty well value for money.also it is being sold in pune,very nearby of mumbai....
as you play downloaded meterials ...90 percent of them are dts only or DD only....so a optical or coax is enough for 5.1 channel carry....
so non hdmi avr is enough......
even if you play a blu ray suppose in a blu ray player...you wont lose much..the dts hd ma will be downmixed to 6 channel Dolby digital.....
I have selected this for E bay global easy buy, Is it safe to buy that from there, it suits my budget. I am not having confidence to buy such a big amount item from global easy buy from e bay. What you can say about Energy take classic 5.1, it has got good reviews. Also Pioneer Spk-PK21BS package is also have good reviews. whats your take on these systems.
My order contain denon 1513 and energy take classic from Some seller electronic expo in Wayne NJ, USA. Is it safe bet.
