Which one is better Yamaha 3067 or Pioneer VSX 531?
babu82
Hyderabad
Dear All,
Please suggest me which one is better?
Can I connect my existing Sony IV 300 speakers to any one of these AVRs?
For me Bluetooth feature is not a problem.
Thanks in advance.
Having owned a Sony HTIB, I can confidently tell you that those speakers may not be compatible to hook up with any AVR, because they have a weird impedance of 3ohms. Probably sony uses this low impedance to get more power out of them. Both HTR-3067 and VSX 531 may need at-least 4ohms speaker impedance.
As a Yamaha user, I feel the AVR is value for money and adapted for both movies and music, off course you can't compare the music quality to Marantz.
With regard to the latest codecs, both these AVRs work with DD, DTS, DTS-HD MA, DD TRU-HD so they cover almost everything barring ATMOS.
Hope this is useful.
Thanks & Regards,
Rajiv
Hi Rajiv,
I think, based on my Sony specification below, only center speaker works.
subwoofer is passive so it wont work.
Total (Reference) 1000W
Front (Reference) 125W, 30%, 3 ohms
Center (Reference) 250W, 30%, 6 ohms
Surround (Reference) 125W, 30%, 3 ohms
Subwoofer (Reference) 250W, 30%, 6 ohms
@ babu82
Any speakers will work with any amp or AVR....the catch here is to ENSURE that either the impedance of the amp or avr is same in most cases....
What can go wrong is that you will face over heating issues....all technical information is available if you google it....
It is better to match the speakers in terms of impedance and output to appropriate amp or avr....
If you are on tight budget lines, look at pre owned stuff being sold on hifiads.com, olx and HFV For Sale by owner section.
All the best.
Hi all,
Thanks for the valuable advises.
I bought Yamaha 3067 AV receiver + NSP40 speaker package couple of days back.
Experience is so far so good. :)
But while playing DTS HD MA movie through android box, AVR showing on display panel as DTS only.:sad:
No problem with Dolby True HD videos.
Hi all,
The receiver is DTS HD compatible, I know that for sure. It must be the android box.
