Xiaomi to launch Mi TV Q1 75" on 23rd March - QLED, 192 Zones, 120Hz
Even I have heard about this from someone in the industry. Their initial batches are of good quality but after a while, they start pushing B grade quality components in their products.
Has happened with Mi Tv that's why shared my concern.
That's very true thinking. FALD are usually brighter. But can you think of any reason of removing 1000 nits from Indian variant? From website.
One of the reasons might be that the 1000 nits is the peak brightness achieved by MI in a 2% or 10% HDR window ( Settings maxed out). General public start assuming that 1000 nits is the full field brightness achieved in SDR . MI can put an asterisk next to 1000 nits but maybe they are wary of certain YouTube influencers who will measure the full field SDR brightness at around 700 or so nits n then spin a narrative claiming MI is engaging in false advertising.
IMO irrespective of the fact whether it is assembled in India this TV will have similar specs/ performance throughout its product cycle .
Very possible. This may be the case.
As per reports by certain reviewers, the mitv cant do 4k at 120hz, whether hdr or not.
Oh yeah, I know it can't do 4k@120Hz, I meant 1080p at 120Hz, should have specified that in my earlier post.
The issue with mi qled isn't bandwidth. It's SoC.
With 'Full Bandwidth' - I meant @4:4:4 Croma sub-sampling, since the SoC is weak (you are right), it can't handle/process that much information required to display 4K,120Hz @4:4:4 sub-sampling.
I think it's perfect to have a great 4k60 experience then. I don't even find difference between 60 and 120 at large distance plus Dolby Vision/HDR10+ can't be done on 120hz.
Some of the better news is that Local Dimming works on game mode.
cant wait for the shield pro to arrive, the UI is laggy AF right now when Playing 4K.
might be OT but do you guys use a voltage stabiliser or any equivalent product for TV and AV receiver? quality of electricity isn’t very good here in Gurgaon. Alol equipment is on a Belkin surge protector right now, which wont do anything for voltage fluctuation
My Yamaha receiver burnt due to voltage fluctuations induced by switching between genset and regular supply. Since then, I have been using APC UPS with surge protector for the entire setup. I have two 600VA powering receiver, sw, TV, amazon echo, wifi router, and broadband modem. Usually, the switch between genset and regular power takes hardly a minute and these two UPSs are enough for that period ensuring there is no power drop and equipments don't suffer brute power on/off.
While non essential delivery have been partially allowed in Maharashtra , MiQ1 75 inch is out of stock on Flipkart and also the HDFC EMI offer is also gone (was valid till 31st May). Mi website is not accepting any orders at all. Anybody been successful to place order via Mi portal
