LG C9 65 - dead pixels; 1.5k hours
ankurgupt
Hi all,
Need some help.
I have a LG OLED C9 65 purchased in Aug 2020, with around 1500 hours of run time on it. Purchased in Mumbai.
I have noticed dead pixels all around the edges of my screen - they are not that visible during TV viewing but there are a lot of them.
My TV is out of warranty but I didnt expect to face panel issues on such low usage.
Can you guys advise on what I should do?
Did you check with a service technician? Probably the panel might also need some cleaning from inside. One of my friends OLED TV had a similar problem like this and it happened that there was dust accumulation on the panel which a service technician cleaned it after removing the panel from inside out.
Hi all,
Need some help.
whats the latest on this?
