Congratulations Sachi and welcome to the club
Tapatalking. Look ma, no computer!
Hi Saikat, those golden inner sleeves do look nice...!!
I used to have the same Numark, that I also bought in around 2008/2009. It was my first TT. It was cool to use at first, but then I eventually moved on to more solid turntables. I found the PT01 a bit too flimsy for my liking. What I found that I didn't like, at least with my model ( I read online that others too were facing the same issue) is that the metal material used to get unglued and scrape the bottom of my record as it was playing. Damaged a few of my records. If yours is working fine that's great, but just be careful that glue doesn't come off.
Happy listening! Looks very well kept, especially like the record boxes!
That looks very like a turntable that I had sometime in early 1980s, which bore the name "Akai" I think.I've taken up a new project, I'm restoring an old turntable I have. It's a 1979 Sansui P-M7. Dimensions (WHD): 345 x 95 x 360 mm / 13.6 x 3.7 x 14.2 inches
Here are the pics of my TT setup.
Additionally each record has been inserted into acid free paper sleeves inner / outer and polythene sleeves for protecting the records that still have the outjacket left.
I am curious to know about protecting the records with acid free paper sleeves - where does one get these from?
haisaikat,
Very well preserved set up. I had a HiQ International till very recently ( 33 1/3, 45 & 78 rpm).
issigonis
