The latest model I think is S490.. which is really great enough. But if you are looking to make it region free, then better opt for Pana 220, which is also brilliant and can be made region free (for details look BDT220 thread by Kix).. BDT220 is not available in India as of now, but you can import from US.
Import from USA means extra money and a voltage converter separately required.
I guess you get Sony bdp-490 for below 10K if you bargain to dealer. Sony has excellent PQ, Pana should be having better sound.(burr-brown dac is available in a slightly higher priced pana, look for it)
Importing from the US is much cheaper when compared to the price of the Sony player which is 13,990/-.
Panasonic 220 from the US - 8100
Region free firmware cost - 2500
Step down converter - 250
Total - Rs. 10850/-
Still you save about 3150/-, with region free player.
Can you give me the site reference for this?
S-490 should be available under 10k, I got it from ezoneonline under 9k with 2 BD movies and 1 Sony 3D spec plus HDMI cable. Still I think it is better to go for the BDT220, which is most desirable considering that it can be made region free.
Sorry for going off topic.. did you get an ADDITIONAL 3D HDMI cable with this offer or the just one in the box? I bought the same deal & was under the impression they would give an additional '3D HDMI cable' as advertised.
What is burr-brown dac?
If you are looking for high quality PQ and BD handling capabilities and decent audio, Sony would be the best option.
Panasonic gives you better sound. Somewhere in audiophile grade.
If you have high regard for audio, choose Panasonic.
I disagree with the above presumptions. Please read my review on Panasonic BDP. I own a Sony as well as Panasonic and the Panasonic is definitely a notch above in all respects, although i must agree that my Sony is slightly older. This view is also reflected in most reviews online by experts.
Sent from my GT-I9100G using Tapatalk 2
You maybe comparing apple to oranges.
Blu ray is a new format and no real conclusion can be derived at comparing 2009 model Sony with 2012 model Panasonic. It can only mislead readers. There must be several changes in 2009 model and new model Sony.
New Sony 490 does have excellent PQ and upscaling capabilities.
Anyway in audio part, burr-brown dac is impressive. Is this player have it?
Hi. For bluray playback almost all players will have similar performance. What Sony does, Panasonic will do and other way round. Demo multiple players and you'll be hard pressed to find any difference. Sounds may be subjective with possible processing difference. Same goes for features and upscaling.
Sent from my GT-I9300 using Tapatalk 2
