Hifi Wood Rack - Group Initiative - SoundFoundations (ali)
option 2 doesnt mean the rack is disassemblable
that defeats the whole purpose
dont you think
option two only means fitting and polish at your end
which is a pretty penny i daresay
we should have a completed finished rack by this weekend guys
you will be able to see the design and finish soon
rgds
ALi
Is it possible to keep the side support at the same level to that of the shelf. so that it does not protrude. If its too difficult, the top shelf can be bigger to cover it.
It is the best an audio rack can get .... simple, yet, just too classy! I don't think anyone is ever going in for your 'other' racks for similar application :p.
Do let me know the pricing on PM .. no immediate requirement though.
Nice work there. I am quite keen but unfortunately it appears that it is not meant for fellas like me who are into HT as well. I am wondering with this thing in the middle, how I can manage the centre channel, the PC cabinet, monitor and keyboard. :confused:
huh ?
the side support is the same level as the top face of the shelf
hi Magma,
from the top the side supports are not protruding above the shelf.
I think FM Ukjeyaraj meant the protruding from sides. Probably he meant that the side legs should completly go in the shelves so that the legs and the panel are in one line from sides also.
hi Ali,
it is beautiful rack as well as a beautiful piece of furniture.
My best wishes for all of your future projects.
Regards, Amit
hi everyone,
excellent design.....
point to be noted....the load bearing slabs (wooden) have not been given cut ..keeping it a perfect square slab. the slots have been cut only on the four legs/ columns...
all the credits for a good design...:clapping:
regards
Thanks for the support
Much appreciated
Yes it's a nice wood rack
I like it
However pure performance wise the theta would better this rack in almost all aspects
The gamma would give it a run for the money too
But yes aesthetic value and waf factor are high on this one I would agree
That would change my design concept
hi Ali,
Regards, Amit
Thanks Amit
Sf has always found support through you
hi everyone,
regards
Not many would realise this
Thank you for the support sir
What also is not noticeable is the steel rod cross bracing embedded in each shelf
Got that idea from one of the rack greats
Hey i knew that the wooden planks are rectangle and the corners are not cut to join the legs, however was not aware of the steel rods.
There seems to be interest from more than 5 FMs, I request you work out the costing now and send me a pm with and without the option of speaker stands of matching look.
You may also want to mention the pricing part in this thread, i feel it is more transparent policy.
Regards, Amit
Sorry guys
Took the weekend off due to the Monday holiday
Mini family vacation
Will be back tomm
Will work on then
Even I am interested. If the budget permits, I will definitely go for it.
A truly beautiful design. Great materials, rock solid construction, minimalistic yet very well thought out design. Very zen. Kudos!
here is the pricing
4 or more racks only
Option 1
18250
option 2
11200
Side columns will be Brazilian TEAK ( one level lower than Burma teak)
includes
shipping to major cities and areas serviced directly by gati
NOte :
this post will be edited once the group initiative is done
The pricing will no longer be valid for obvious reasons
please note : i have edited the pricing from 10500 to 11200 ( i did a miscalculation on the shipping front )
