Hifi Wood Rack - Group Initiative - SoundFoundations (ali)
Questions:
1) In option 1, can we choose the finish of the shelves ? I am still undecided if I want maple or natural wood (cherry)?
2) In option 2, will you be assembling the rack and sending it for us to paint/polish it ourselves or do we have to do the assembling also on our own?
Hi Magma,
There seems to be significant diff between option 1 and 2.
I request you give little more info about option 2.
Regards, Amit
In the case of Option 1, can we choose the height of the shelves ourselves, or will we be arriving at a standard/common shelving configuration (in terms of gaps between shelves)?
Re: Hifi Wood Rack - Group Initiative - SoundFoundations
Questions:
I would prefer all buyers to choose the same finish as pics
Hi Magma,
Regards, Amit
option2
will only have the shelves readied and planed to the size ( 22*18 or 23*18 )
the teak beams with the slots cut out in them
User will have to do the fitting,sanding,polishing
currently
we are at 1st shelf from bottom 6 inches from floor
i was thinking of shelf spacing of 9 , 7 and 6 working from down to up
you will end up at 34-35 accounting for 1.75inch shelf thickness
here is the pricing
4 or more racks only
Option 1
18250
option 2
10500
Side columns will be Brazilian TEAK ( one level lower than Burma teak)
includes
shipping to major cities and areas serviced directly by gati
NOte :
this post will be edited once the group initiative is done
The pricing will no longer be valid for obvious reasons
I am interested in option 2. Can you tell me whether you will be sending the rack fully assembled and we just have to polish it from our side. Slightly confused on this aspect.
And regarding shipping, I guess Gati will have no issues in delivering it to Kolkata.
Let us know.
No sir
Option 2
YOU have to do the fitting at your end using wood screws and fevicol
or commission a carpenter for 2-3 hours
Obviously - Polishing has to be done at your end after fitting
Only the shelves will be planed to size
and the side columns will be slotted at the correct places
though the columns will be machine slotted and the shelves will be machine planed a small amount of filing may be required
The thing is
i do not want to make the slots oversize so that the shelves just glide in
(that will introduce sway)
the shelves should fit in tight
for this the slots must be slightly undersize and then you need to file a bit till it just fits
ok
RMCWS,vinehs,AmitKumar,gopib,ukjeyaraj,panditji
am i missing anyone else out who had shown interest ?
please confirm here which option you are comfortable with
Also let me know if you have opted out
I am in but would prefer that you assemble it so that I need to only paint/polish it at my end....also if I have to paint/polish at my end, can I get the colour of the shelves natural cherry wood? Not interested in the maple finish...
panditji
if i assemble it - price gets close to option 1 (15.5k)
are you ok with that ?
if you opt for purely option 2
i will NOT be polishing sir
you can choose whatever shade (maple cherry teak etc etc) you want - that is between you and your polisher
P.S if there are no takers for option 1
ill have the rack finished with your shade
PLEASE noTE : i have ediited the pricing of option 2 by about 700 rs due to a miscalculation in shipping cost
hi Magma,
I am waiting for the costing and design part of matching wooden speaker stands with option 2.
I have some smaller doubts, Pls help me understand following:
1) the picture posted by you have 5 planks, so this pricing is with 5 wooden planks?
2) do the planks and legs will have predrilled holes? Then we just need to fix the screws. In such case carpentar might not be required, you will need basic tools and a helper.
3) will you provide the wooden screws or i need to buy myself?
4) can the shelves height be customised? Everybody has his own choice and preference? Can i avoid 6 inchs space below the bottem plank, i feel ideal space should be around 3 to 4 inches?
Hope i have not asked too much.
Meanwhile you have any experience with XPS cargo, not sure abt the charges. Two years back one large dining table with chairs was sent to me via XPS cargo from Jodhpur. Otherwise Gati is fine for me.
Regards, Amit
stands
i am not getting into now
i will finish one thing at a time
pricing is for 4 shelves
no pre drilled holes in option 2
no wood screws
everyone has to arrive at a consensus about the shelf spacing
you may confirm your order on the thread
then propose shelf spacing
Ball socket
self adjusting footers with damping
for Wood Racks
these will be charged extra though
price for only participating (in the group initiative ) members rs 200/footer
Hi Ali
I'm interested, but will take a decision in a day or two and confirm, only looking at Option 2-the "kit" that is to be assembled by the buyers. Could you spell out the purpose of the ball socket self adjusting footers a bit more? I haven't understood their function.
George
Hi Ali,
I am still interested in option 2 as I need to match the colour with existing furniture. I will decide once the final measurements are known.
It will help if you call out the measurements as follows: (please edit as you please)
1. Height from floor to top of topmost shelf = 35"
2. Spacing from floor for lowermost shelf = 5"
3. Spacing between Shelf 4(lowermost) and shelf 3 =
4. Spacing between Shelf 3 and Shelf 2 =
5. Spacing between Shelf 2 and shelf 1 =
6. Size of shelves = 24" x 18"
Other specs. for option 2
a. Shelf is made of Brazilian teak
b. Pillar is made of Brazilian teak
c. Shelf has rods for strengthening
d. Pillar has slots which are machined accurately on all four pillars to match.
e. Shelf has holes to match the pillars
f. The top shelf is flush with the top of the pillars.
Exclusions for option 2
a. The shelves are only cut to size and machined for plane surface
b. The pillars are also machine cut appropriately for the shelf slots
c. No Polishing on either the shelf or the pillars
What we have to do with option 2
a. Sand the shelf and polish appropriately
b. Sand the pillars and polish appropriately
c. Procure wood screws and glue
d. Fix shelves to pillar using wood screws and glue
e. Check levelling shelf by shelf
Of course we will get the professional to do it.
Ali, Please do edit the above and add/delete as you may please. I have just listed them all. Once you spell it out let us get interested members in and close either way,
For option 1 if thecolours agree with most members then it may be good one too.
gopi
Hi Ali
George
the ball socket allows the rack to self adjust ( level ) even if the T nut that is hammered in inside the leg is cross (i.e teyda i.e at an angle rather that perfectly 90 degrees )
the Polymer mould around the ball socket allows you to move the rack without scratching the floor
Also the inbuilt hex allows you to level the rack on an uneven floor
i have noticed that wood racks function much better on these rather than on spikes
but this is just my personal experience
Hi Ali,
Anywhere between 32-35 inch- i say anywhere because i dont want to be held up for an inch here or there - this is custom fabrication - i decide on the spot many a times depending on the wood
this i can do whatever everyone (consensus) decides -
i would prefer
the height between the floor AND the lower most edge of the lower most shelf
to be 5 inches - this includes the polymide footers
after that things start getting ugly)
im looking at 9" - but whatever consensus decides
im looking at 7 inch but whatever consensus decides
im looking at 6 inch but whatever consensus decides
No this i will decide on the spot
right now you guys only need to decide how much INTERNAL space you want
i will calculate the part that goes inside the slot my own on the spot
currently i would prefer
internal size to be 20.5 inches wide
internal depth to be 18 inches
that allows you to easily place 17 inch wide equipment but also squeeze in 19inch equipment
it is highly probably one would end up with a rack 24*18 (external dimns including the pillars
shelf thickness can be anywhere between 1.5 inch to 1.7inch
NO
this is going to be a the maple equivalent in India. Similar to rubber wood but a natural wood - NOT panels
YES
No
that was only in rikhavs rack
shelf will take on 50kgs -and look exactly as in the pics above that is all i can promise
Rods or not - that call will be mine when i go into manufacturing
YES.- small amount of filing is possibles - since for a tight fit i will machine the slots slightly undersize
NO
that your carpenter or you have to handle
YES
a small bit of filing may be neccesary during fittamant
that has to handled at your end
SIRs if you think you are looking at a modular furniture setup where all you have to do is assemble everything and everything lines up perfectly as it would when you buy IKEA furniture
then please do not buy into option 2
Understand that a carpenter will be required (3hrs to 5hrs - at least that how long mine took )or a good DIY hand
this is hardwood you are dealing with
NO modular machine made MDF furniture where everything is accurate
option 2
the above is 100% correct
a. Sand the shelf
b. Sand and file the pillars
Pilot drill the shelves and pillars once you are alligned
gopi
my answers in BOLD
Ok understood. I am confirming one Option B. I may be interested in two sets of the footers if you think I can use them on a wooden base for one of my floor standers, to have the front face slightly angled upwards. I was looking for something like a machine mount, this looks like it will meet my needs.
Anyway please PM me when the group buy is a go, and I will take it forward.
George
The Group Initiative for the HIfi rack discussed above is a GO
Most are intrested in the option B
so that is what we will go for
details refer post no 78
price option B - 11800 -
Footers will be 800 rs extra for the set
one FM (ukjeyraj - i think) wanted a small modification on the top shelf
he is requested to specify that by email to me
intrested members must confirm on this thread
ukjeyraj.georgeO,gopi,panditji etc
please note
the rack will take a bit of time -
my factory is a bit understaffed
the wood screws will be provided by me
they will be stainless steel
so all you now need is a carpenter with a drill machine (for pilot holes) and fevicol
and the polishwala
a good diy hand should be able to manage this too
