Samsung Plasma 51F5500 Owners Thread /Reviews/Discussions!!
Finally bought Samsung 51F5500 and got it delivered today !!!
Thanks to all the experts in this forum for the help and advice.
I will be getting a BDP ( BD-F5100) free as part of the Diwali/Dussera offer.
I am so happy with this purchase after an year long wait :)
Thanks,
Sunil
Thanks,
Sunil
Congrats sunil.. How much did you pay for it.. And where did you buy it..
Been reading the entire thread, quite envious of all of you.
OT warning, please skip if finicky
I have a 51E490, purchased Sep'12 for 69k ( got my Dad to buy a 51E550, for his house @74k in Dec'12) .. Mine is a Semi-smart TV with Allshare, and Wifi Ready(not built-in), Lan in port, and 3D. Loved it so far, beautiful clarity through the HDMI input, and smooth file browsing/accessibility/compatibility to my USB pen drive (buggers disabled reading HDDs, though some still work).
Audio is good enough to fill my small ~150 sft living room, though I'm looking at sound bars as well at the moment (inspired by you lot)
Settled for the E490 rather than the 15k more expensive E550, didn't do any research, more of an impulse upgrade (:P), so didn't realise it's only 720p, not full HD at the time. But I'm probably not picky, so I've enjoyed the quality of the output from even 1 GB files, and the 3D is mindboggling as well! Only 700 MB files had ugly blocks/artifacts..
Enjoyed streaming HD music videos from my Samsung Note N7000 -> (wifi) -> Router -> (lan cord/wifi adapter) -> TV via either the default Samsung phone Video player, which can recognise when the TV is on the same network, and shows up as a small icon, or via "Skifta" android app, which allows my to browse my laptop collection (online via the PC MediaServer software) from my phone and send something to play on the TV.. Allshare server has been acting funny for a while.. In fact with the Skifta mediaserver software, and server enabled, even been able to browse collection directly from TV.. :)
The audio 3.5mm out port didn't work too well for me when I tried, and regrettably didn't explore it enough, else could have tried to pursue an exchange... :P
Reflections from windows that ppl have mentioned are true here as well, was a bother earlier, but in it's current location, there are no direct reflections/etc..
Have a WDTV Live player which acts as my hub to connect HDDs, and to browse Youtube.
Apart from the semi-handcuffed USB port, other misses for me are the lack of HDMI ARC, and the port positioning at the back which means larger HDMI cables don't fit in easily..
Oh, and messed around with Autocalibration in the service menu recently, screwed up the A/V input colours, now got it back to usable, but there is some shortcoming. :( Luckly HDMI is still fine.. (Warning to all- do not mess with the ADC -Auto calibration settings in the service menu, you will most likely regret it)
Otherwise I'm loving it... :)
Edit:
15A plug came with my TV too, bringing perplexion and inability to test the set when it was wall mounted.
Finally solved problem with a cheap 5A->15A converter multi-plug (Rs. 30-80 I think), which takes my TV, my extension box (which has the WD/Hathway/Router/chargers/amp etc. connected to it), and no problems since Sep'12). Only con is that it bulks up the entire plug sticking out from the wall ( cumulatively almost 10 cm out) , and slightly covers one switch on the board.
I have bought V-guard crystal plus ( Current capacity : 3A ) model and Belkin surge protector strip to use with 51F5500. Will be connecting the TV and BDP only to this. Hope this is fine.
Planning to connect like this:
( Have read multiple threads discussing this and want to confirm this connection is ok)
MAINS - APC 850A Inverter/UPS (power backup in all 5A sockets) - Belkin Surge protector - Crystal Plus stabilizer - TV and BDP
Tatasky STB I will connect directly to Belkin surge protector as it has 4 sockets.
Please advice if the above connection is ok.
Initial TV setting: Owners and experts please help.
1) Can I just set the pic mode to "Standard" for the first 200 hrs or should I adjust contrast, cell light, brightness etc independently?
2) Please share the TV settings to be done for the first 200 hrs.
3) Is there any restriction on number of TV usage hours per day during the 200 hrs of break in period?
Forgot to include this in my previous post:
How did you all check the usage hours? Is there any way using touch remote?
Will the technician show this during the installation?
Excuse me for the over excitation :)
This is my first flat panel TV and upgrade from 29" CRT..
Hi sunil.. The power supply seems okay according to me.. The inverter makes the use of a stabilizer very less though.. Yes there may be voltage surge during mains.. So it's good..
Regarding the break in period..
Use tv with minimum cell light and if using a stb push the logo out by zooming in..
Or even better use USB movies for some time..
After getting used to watching with minimum light I suddenly have a difficulty when the brightness is high.. I'm okay with the slightly dim picture since it is easy on my eyes in the mostly dark room I watch..
Other than that.. No specific issues I guess..
I had updated earlier in Aug.. Got another update now.. So connect it to wifi and let it do the job in support in menu..
Congrats! The best vfm panel out there.
There are break in slides. Basically bunch of jpgs with solid color. Run them in slide mode. Every night till you hit 100-200 hrs. People claims that, this process will age the panel evenly.
Do confirm the panel usage time, during installation.
I have read in cnet articles that break in slides are not mandatory.
Is it really needed or anyone used these slides in 2013 PDP
I cant find demo of this set in whole Nagpur....plz help me to take final call... Plasma PQ or LED PQ ??? i dont care abt 3D and INTERNET..
51F5500 OR LED 46F6100 ???????????? Going to buy 2moro
You could read this thread: TV Buying Guide - LED (LCD) or Plasma
Note that it is slightly biased towards plasma. Plasma models may see their end very soon. If that makes you uncomfortable, go with LED. I, personally, prefer plasma.
Hi just4kix,
I have gone through your posting before buying tv and downloaded Evangelos breakin slides. In fact most of the plasma related threads are bookmarked !
I have tried to push the channel logo by zooming. But it is not completly out of the screen (eg zee tv and some malayalm channels) is there any work around for this?
Using tatasky SD connection now.
Tv installation was done today. Wall mounted.
I am using the below setting. Lowered cell light , contrast and brightness
Cell light 10 (technician set this as 15)
Contrast 40 ( his setting was 85 )
Brightness 40 (his setting was 50 )
Sharpness 15
Colour 40
Tint (G/R) in the middle
Technician did the below advanced setting
Dynamic contrast - low
Black tone - darkest
Flesh tone - 0
Rgb only mode -off
Gamma - 0
Is this settings fine? Could any of the owner can share their setting or advice ?
Sunil you got it at a good price as the BDP is worth 7K or more.
Your settings for the initial 100-200 hours is fine. Occasionally use the break in slides for few hours, if possible ( I kept one whole night running 11pm to 7am). Regarding the zooming it should be done sometime so that there is no static image. Portion of the logo still appearing will not harm. Better still see few full size movie from USB so that it is without logo and no black strips (on top and bottom) of wide screen movies. So better download few old movies or play it from BDP.
So the mantra is no static images should be kept. So keep zooming, keep changing channels, watch full screen size movies, use break in slide whenever possible etc.
Initial impression is just awesome!
We are really having a totally new TV watching experience, especially most of the english movie channels looks so good. I am planning to upgrade to HD DTH ( mostly Videocon D2H) from the present Tatasky SD to have the HD viewing experience.
