Netflix, my experience...amazing service!!! can be accessed from INDIA as well..:)
Re: Netflix, my experience...amazing service!!! can be accessed from INDIA as well..:
nSinghal: while every router allows you to change DNS manually, only a DD-WRT router will work with Chromecast. That is because Chromecast uses a hardcoded DNS that overrides whatever you key into your router.
For Roku, Xbox etc. you can go with any router.
You mean any router will work with chromecast, roku etc as long as I add DNS manually in the router setting?
Yes and No :) . It should work in case of roku etc but Chromecast will need Flashcasting to bypass google's DNS check. I am using two chromecasts - one with flashcast which I use for netfix etc. other one is not flashcasted and is used for youtube etc. ..which do not require DNS.
Hi Folks
I'm using unotelly to access netflix. I have a 8mbps Airtel broadband connection, which provides decent speed (when checked on speedtest.net)
still, I dont get netflix in HD. Infact its pretty bad quality when I see it on my ipad
Pls help
Hi Folks
Pls help
Try unlocator.com and see if it makes it better. I have been using it through chromecast @ 8mbps from Noida :) and I do get HD with 5.1 sound.
I'm in noida too. Tried with unlocator, same story :-(
That's weird - are u using it on browser or through a device ?
For now ive tried unlocator just on browser. Ive tried unotelly on my ipad and browser
try unlocater on iPad or any non-browser device as well. I dont know y but sometimes I have see the netflix didnt go HD on browser whereas on chromecast it did.
Ive tried both unotelly and unlocator on browser, android, and ipad ... no luck. No HD anywhere.
its quite frustrating. I checked on each device, im getting downspeeds of 8 mbps
No suggestions?
I haven't yet seen HD on my ipad. Have tried pretty much everything from unotelly to unlocator and a bunch other DNS services. Might have something to do with the app. Even on the xbox I rarely get HD. It's only the ps3 which gave me full 1080p no matter which service I was using.
Hi Folks
Pls help
Use the stream manager in browser fro netflix and see which bitrate its streamin. You can manually set it to higher bit rate if you want and see how the perfomance is. To invoke stream manager you need to press Ctrl+Alt+Shift+S while you are in windowed mode in a browser. Make sure your vidoe is playing at that time. If nothing is happening then click on the center of the screen and press the required buttons once more. It will clearly give you an idea.
using vpn makes netflix slower, its better to use unotelly dns service :) .. but that might not work on your mobile phone..though works on smart tvs, apple tv and computers.. its better and nothing geeky to do service..
just change your dns!
Hi Guys,
Use unlocator.com.But before u login to netflix u have to update ur ip in the unlocator site.It will work with all of your gadgets including ur phone.No drop in speed and i am getting hd pics through roku 3.
And u know what.. unlocator is FREE.
Tunlr was also another free service that i was using, but unfortunately they stopped operations. There were plans of becoming paid service. But they stopped completely saying that they did not have the time and bandwidth to keep this operational as it required lot of effort and going paid would increase the workload.
What a loss it will surely be missed. Pasting a note pasted on the Tunlr site below :
Tunlr Has Left The Building...
A little over two years ago we started Tunlr as a fun project. It was a steep but interesting learning curve and we've developed many ideas, skills and code snippets which we will be of use in future projects.
However, while preparing the paid plans we recognized that we had no desire to run Tunlr as a paid service. Running Tunlr as a good-quality and reliable, paid service requires more time than we're willing to devote to the cause. We didn't want Tunlr to become one of the many mediocre DNS unblocking services available on the market today. That's why we pulled the plug. None of your account data will be shared, all account data has been destroyed.
A few facts about Tunlr:
At its peak time, Tunlr had more than 100,000 (anonymous) users
During this time, the bandwidth for Netflix alone exceeded 30 TB of data/month
With the introduction of Gatekeeper 2, 30,000 accounts were opened in the first two months of this year
Tunlr was running mostly on dedicated servers in order to cope with the demand
The operational cost to run Tunlr's infrastructure was well below $1,000/year
Anybody facing issue with unlocator ? I am not able to connect to netflix. Inspite of having 3 green checks, whenever I am trying to connect to netflix, unlocator error msg is popping up ?
I checked their support, not getting much help either.
Just got an email from unlocator that they have changed their DNS servers to
185.37.37.37 and 185.37.37.185
Well you missed the most important part that unlocator is moving out of Beta in few weeks and going paid. So is there any other free service left out there, as Tunlr also shut shop. High time we started searching for one, else going for paid service would be the only option.
Even with the new DNS some isssue is there in Netflix and it is not working properly, it is not loading giving messages unable to play the titile now sometime the loading bar is getting stuck. So post moving to new DNS, definitely some issues going on with unlocator.
Tell Your Friends
Please tell your friends that the Unlocator BETA is soon coming to an end (most likely in a couple of weeks). If they want to be part of the BETA, they need to get on board now. Share on Facebook and Share on Twitter
Once we leave the BETA, all users will have their BETA account transformed into a free 7-day trial. From then on, you can upgrade to the paid version, which will be $4.95/month. However, we are going to run a special offer for the first week of the live service. More about that in a later mail.
Please note that you will not be charged anything unless you choose to upgrade the Unlocator BETA is still free and no credit card info is needed to create a trial account.
Is there any DNS works for HBOgo. Unlocator is not working for HBOgo though they included it in their site. However Netflix works fine for me.
You cannot use HBOGo, unless your cable provider is associated with it, even if the website opens. You have to have an account with your cable provider to have HBO Go, and all cable providers listed are of US and will require proper digi codes for an account to be created.
