sachu888
I think they are Bolton.I talked to an ex Cosmic employee today. He told me Cosmic used Bolton drivers.
Sachin
Sachin
Sachin
It is water proof and very heavy. Will need to check the grade.San
I hope that is not exterior grade mdf
They seem stronger but are not great for cabinet builds and don't take kindly to screws as well
I called up that Cosmic employee, after our telephonic conversation. He has confirmed that they are Bolton, made in India(Delhi)Bolton used to re badge corals, I have heard.
regds,
shafic
I called up that Cosmic employee, after our telephonic conversion. He has confirmed that they are Bolton, made in India(Delhi)
Sachin
Nothing great in it. He is from Gujarat. Few FMs also know him.Great work sachin!!:clapping: I thing he is from Navi Mumbai,right?
Green and pinkish coloured MDFs are usually outdoor grade. I don't know for sure if they're called HDF but they're costlier and denser than the regular MDF which are usually pale brown in colour.
I don't know about the cement - maybe some manufacturers use it but it's not true for all exterior grade MDF. At least the ones that I'm aware of use different types of resin for different grades of MDF.cement is added to the MDF
that makes it exteriror grade and more resistant to water
Back view of the driver I have.
I am attempting Tapered Quarter Wave Tube (TQWT) design, which I have read is a little forgiving design and I can compare different FR drivers in it.Hi sann. Really curious to know what kind of build you're doing.
Care to share some details with us please?![]()
@ Danial john,
Sir, I have a pair of Cosmic 2 way speakers. These speakers are producing nice sound according to my ears. With my Marantz 1060 they are singing. I suspect the mid-range driver is CORAL. Can you identify these, pls?
Here is the link. They are looking like same. May be they are CORAL 8' II.
Coral Speakers
regds,
shafic
I recently acquired Bolton 20BF22, 8" fullrange drivers.
There is no specification available on the web. Does anybody know / has measured their TS parameters? Also please suggest a cabinet design for them. Will TWQT be a good idea?
I am curious to know how this driver performs in a TQWT. Will you be able to share frequency response plots
Today's progress.
