Bolton fullrange drivers
San
I hope that is not exterior grade mdf
They seem stronger but are not great for cabinet builds and don't take kindly to screws as well
It is water proof and very heavy. Will need to check the grade.
Green and pinkish coloured MDFs are usually outdoor grade. I don't know for sure if they're called HDF but they're costlier and denser than the regular MDF which are usually pale brown in colour.
actaully they can come in any color
depends on the company making them
cement is added to the MDF
that makes it exteriror grade and more resistant to water
Back view of the driver I have.
I don't know about the cement - maybe some manufacturers use it but it's not true for all exterior grade MDF. At least the ones that I'm aware of use different types of resin for different grades of MDF.
Hi sann. Really curious to know what kind of build you're doing.
Care to share some details with us please? :)
I am attempting Tapered Quarter Wave Tube (TQWT) design, which I have read is a little forgiving design and I can compare different FR drivers in it.
@ Danial john,
Sir, I have a pair of Cosmic 2 way speakers. These speakers are producing nice sound according to my ears. With my Marantz 1060 they are singing. I suspect the mid-range driver is CORAL. Can you identify these, pls?
Here is the link. They are looking like same. May be they are CORAL 8' II.
Coral Speakers
regds,
shafic
Shafic open & see it for yourself so you still remember the Link which my brother Robin gave huh.:)
I recently acquired Bolton 20BF22, 8" fullrange drivers.
There is no specification available on the web. Does anybody know / has measured their TS parameters? Also please suggest a cabinet design for them. Will TWQT be a good idea?
Here are the TS params. These are the measured parameters of the two drivers that I have.
Drivers with high Q as these are more suitable for Open Baffle.
Bob Brines recommends a Q value between 3 to 5 for TQWT. Quarter_Wave_Resonators. I am curious to know how this driver performs in a TQWT. Will you be able to share frequency response plots of your speaker?
Bolton 20BF22 8ohms 40W Fullrange
Thiele-Small parameters:
Fs = 58.93 Hz
Re = 7.70 ohms[dc]
Le = 352.98 uH
L2 = 469.44 uH
R2 = 3.77 ohms
Qt = 1.35
Qes = 1.68
Qms = 6.81
Mms = 13.70 grams
Rms = 0.745250 kg/s
Cms = 0.000532 m/N
Vas = 30.23 liters
Sd= 201.06 cm^2
Bl = 4.817540 Tm
ETA = 0.35 %
Lp(2.83V/1m) = 87.75 dB
Fs = 57.68 Hz
Re = 7.70 ohms[dc]
Le = 426.33 uH
L2 = 463.29 uH
R2 = 1.63 ohms
Qt = 1.49
Qes = 1.76
Qms = 9.67
Mms = 16.50 grams
Rms = 0.618569 kg/s
Cms = 0.000461 m/N
Vas = 26.20 liters
Sd= 201.06 cm^2
Bl = 5.118018 Tm
ETA = 0.27 %
Lp(2.83V/1m) = 86.66 dB
Thanks a lot for the data. I will definitely try to measure the response. I just played one speaker today, without damping the cabinet and only one out of three deflectors in place, the initial impressions are very encouraging. I will also try two comparatively lower qts drivers I have Philips (1.26) and WB Betsy (.78)
