spirovious
This is another champ from Toshiba-
Toshiba SD-390E DVD player review - from the experts at whathifi.com
Silly question, but i am not able to see out put if I use HDMI:sad:. Can some one help me out establish the connection. I have Sony AVR , DVDp (No HDMI) and setup box. The connection which I have made is Setup box to AVR normal cable and from AVR to plasma through HDMI (1.3),But no picture only audio is coming. please help me out. is there any setting we need to do for HDMI?if yes then where we need to do that?
Thanks in advance.
Thanks in advance.
Thanks in advance.
can I have make and model numbers of ur equipment?
Just now I called Sony customer care and they told me that HDMI will work only for Audio not for Video. As per sony HDMI will work only this way if you have Setup box with HDMI option then Setup box>>>AVR>>>Plasma or other way is DVDp with HDMI then DVDp>>>>AVR>>>>Plasma so if you do not have HDMI setup box then you need to give direct video connection from Setup box to TV. My requirement is i want to pass my audio/video through AVR. I do not know whether it is possible on not. illusion please share how to do Amp setup?Hi you need to assign the video in to your HDMI . By deafult Sony avr have only pass through connections for HDMI . For this you need to access the amp menu .Assigning has been given in details in your Amp User Guide !
Also make sure you have connected hdmi to HDMI out from AVR to Plasma.
Connect your setup box to your plasma tv directly for video using component or composite depending upon your setup box options. I am assuming the setup box does not come with hdmi out.
Use the AVR for the audio part of the setup box.
so HDMI will be in this way only DVDp>>>AVR>>>Plasma. right?Hmm then there are two ways of handling this :-
1)do as sud98 tells you . Keeo the avr only for audio with the video connection directly to LCD
2)Or plug in an additional composite cable to the video out of the avr and then run it to your Plasma. You will be routing your video thru avr but If I were you I would go with Pt 1.
My 2.5 year old LCD has at present only one HDMI port. I have connected WD TV and DVDp to the two HDMI ports and plugged in the HDMI out port of AVR to LCD. Working beautifully.
Yours is a case when the signal has to be upconverted which the Sony AVR does not support and hence the problem.
Anyways I was wondering does any LG DV 388 owner has a LCD which supports 1080p thru components ? I think the LG 388 has the capability to send upscaled video through components .
Yup For Hdmi out to work you would need HDMI in as well.
So no use of HDMI as non of DTH providers are providing HDMI option.
Lots of format supported thru USB as well
