Received pm5005 today from hifimart.
There is no warranty card nor printed invoice inside the box.
Is that normal?
And there is warning on the box which says warranty void if used on ups/ inverter power supply.
What if I have a pure sine wave ups?
Hi FM,
Bought Creative Sound Blaster Roar SR20A few days back - Sound Blaster Roar - Portable Bluetooth Wireless Speaker with NFC; 5 Drivers with a Built-in Subwoofer | Creative Labs
Features / Specs:-
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands Free Profile (HFP)
Integrated Components digital recorder, microSD card reader, Alarm, TeraBass, Roar function.
Connectivity Interfaces Bluetooth 3.0, Near Field Communication (NFC), USB
Speaker Channel Type stereo, subwoofer
Speaker Channel Qty 2
Amplification Type active
Driver Type passive radiator, subwoofer driver, tweeter driver
Connector Type 4 pin USB Type A, mini-phone stereo 3.5 mm
Hands-Free Function Yes
Audio Amplifier integrated
Connectivity Technology wired, wireless
Controls call answer, power on/off, volume
Built-in Decoders SBC decoder, aptX
Supported Digital Audio Standards AAC, MP3, WAV, WMA, apt-X
Rechargeable Battery rechargeable
Technology lithium ion
Capacity 6000 mAh
Run Time (Up To) 8 hour(s)
Is that normal?
Congrats :clapping: for PM5005!! that's normal and just a warning. Get warranty on billing date. Enjoy your setup :) :cool:
Hi FM,
Features / Specs:-
Capacity 6000 mAh
Congrats!! :clapping: how it sounds compare to JBL Extreme?
IMO they sound more towards bass heavy & i feel little bit more of highs could have been sweet. However been said its complete VFM. Can easily replace any 2.0 within 10k budget. Got some serious features which you can hardly find in these range BT speakers :clapping:
With TeraBass - On & Roar - On it certainly delivers that punchy & room filling sound.
On the scale of 1 - 5 (excellent)
Build - 5
Sound - 4
feature - 4.5
Connectivity - 4.5
If your looking for portable speakers with BT & other Connectivity features within 10k then don't look any further. This is the one :thumbsup:
:cheers:
Build - 5
Sound - 4
feature - 4.5
Connectivity - 4.5
:cheers:
Nice . Enjoy!! I wanted to but wife won't allow another audio component, just bought PM5005 and Schiit Multibit :argue:
Congrats, it will be paired up with? Have heard some good reviews about it. Njoy maadi !!!
Paired with Tannoy Mercury V1 (86db). Drives them quite easily, fills my 8x10 room at '15' volume level. Compared to my hifimediy T1 this one has a lot more punch at low frequency so turned down bass to -4 (max -9) for easy listening.
As of now feeding the analog input from my ES9023 i2s dac. Need to test the inbuilt DAC. Planning to connect the chromecast audio to optical input, has ordered the cable for it
