Some pics:
The rear showing sockets for audio outputs and power input and AC voltage selection:
A closer look at the audio ports:
Part of the control panel. The figure of 8 button toggles between mono and stereo.
Tonearm controls: spin, stop spin, drop arm, raise arm:
EMT TSD 15 MC cartridge:
Tracking force of 2.5g:
Few setup points:
1/ levelling of the table is easily achieved by adjusting the four threaded rod footers.
2/ for power cords Prem has decided to go back basics by using regular computer power cables. No fancy cable. The schuko pins of both the power cables for TT and amp were chopped off and were directly twisted to the power cable in the wall, and protected with plastic wire nuts.
3/ TT to amp balanced cabling uses very cheap Studiotechnik Dusch cables. This cable works very well.
4/ speakers are roughly placed without any fine tuning of position done with earlier TT.
5/ Left and Right channel balance adjustments are done from the built in phono preamp of the EMT 950. We struggled a bit here because we did not apply our minds
. Neither did we read the manuals
. I was reminded of the classic instruction, "RTFM".
6/ Arm came pre-balanced so there was nothing to do here.
7/ the usual room tuning devices did not work. Or more precisely, they were not required at all. There seems to be no need to compensate for the limitations of equipment.
First Impressions:
From the very first notes it was obvious that the 950 is a very different animal from the 938. We had big smiles from the moment we started listening. The most obvious difference was in the bass weight and texture. It has subterranean depth. The nuances and texture of bass are superb. With the 938 playing Stevie Ray Vaughan's Tin Pan Alley the quality of bass was my personal reference bass. The 938 is left far behind, biting the dust. A deep bass is no good if it eats into the all-important midrange. The Tekton Double Impact speakers demarcates the bass and mids distinctly, yet they play together as a "band" in harmony. I remember mentioning twice to Prem last night that the singer is in the room. Timing is spot on and there is a smooth sense of flow to the music. The same EMT TSD 15 cartridge is used but the amount of extra details the 950 digs up is amazing. The highs are delicate and ethereal. If I am to characterise the sound right now, I would say that it has an amazingly deep bass combined with delicate highs. The mids are a given, of course. A dream combo, in my opinion.
The 950 is certainly an upgrade over the 938 by a comfortable margin.
The balanced signal cable is new and will improve with burn in. Prem is expecting a couple of unconventional speaker cables. I am guessing things will improve further. All in all a punt that paid off exceedingly well.
