@Dr. Bass, nothing beats a DD or an idler for PRAT... do get your hands on a DD or idler as a side project... analogue is all about experimentation...
The best PRAT I have heard till date from a turntable was in Avid Acutus...a belt drive
somehow, thanks button seems inappropriate..! wheres congratulations button?![]()
I saw a big box, thought it must be, maybe, a power amp.
Enlarged to picture to discover it is the phono pre-amp!
Wow.
All teamed with an old name in British hifi. How is Naim? ten or more years ago, it was considered an acquired taste. Now I wonder if this might have meant that it gave a natural sound?
Errr... No pun intended, even my sense of humour is not that bad![]()
Thanks, I'd like to.Whether they sound natural or not that I would request you to listen and judge. To me it does.
I fear that it may be much more so! EnjoyI know there are always so many things to take care of in analog and also so many things to try but I hope it is not as compulsive as in digital![]()
How about making the bridge? Probably those who invest a considerable amount of money and time in superb TT/phono setups would consider it sacrilege to use them for digitising, which is a pity as they would probably get the best results. Just a thought: not an attempt to start any kind of digital/analogue debate in this thread![]()
MAJOR ROADBLOCK
I will be putting the Leben phonostage for sale. I dont know what I can replace it with, I will have to research.
....The low-frequency output impedance was ridiculously high, at 28k ohms at 20Hz, and was still an extremely high 14k ohms at 1kHz and 6k ohms at 20kHz. The RS-30EQ needs to be used with a preamp having an input impedance of at least 100k ohms. (The CS300 just about meets that need.)
Abhi really Sorry to hear this...
Check this out
Leben RS-30EQ phono preamplifier Measurements | Stereophile.com
Hi Abhi,
Before you put your Leben phono preamp for sale, try it with an outboard tube buffer, to bring the overall impedance down. This is what Leben themselves should have done - I will venture to say that it's poor design to send out a product with that high an output impedance.
Something like: http://http://shop.grantfidelity.com/B-283-Tube-Processor.html
Viren
hi abhi, being in singapore changing your phono should not be that tough and the leben sells well. i feel you could just change it unless the sound signature is something you cannot compromise.
why not a Naim phono stage![]()
