You must be having the boss2 with the aluminium casing. It severely impacts the in-built wifi. Also signal quality means nothing if you have interference. Interference is the biggest reason for bad wifi performance. You may be surrounded by neighbours with wifi on the same frequence+channel. You can try changing the wifi channels by login in to the router. See this guide. You can google and get better guide to help you optimize wifi efficiency.so the allo boss 2 i have is connected over wifi and my home has a netgear orbi placed which covers well.the signal quality is around 77% at the device.The allo started malfunctioning only since last month.
I have moode r761 installed.downgraded from r8.0.2 because of airplay drop.
To troubleshoot i tried volumio.same kind of airplay drops.
anyone have any idea if the allo needs a wifi adapter or its a case of the rpi inbuilt network card gone bad?
If i want to buy network usb adapter what should i buy??
WiFi Optimisation Guide | Increase Broadband Speed
Improve Your WiFi Connection to Substantially Speed Up Your Broadband. Incorrectly Set Up, WiFi Can Ruin Your Internet Speeds!
If changing the channels / bandwidth doesn't help, you will have to look for an external wifi dongle.
The following listed on the allo page can also be purchased from fabtolab, etc
If your allo boss2 is at a fixed place, use ethernet cable. Keeping convenience aside, Wifi sucks and will always suck and will never be able to beat good old ethernet connection. If you can connect your boss2 to the router using an ethernet cable, nothing like it. With ethernet you will get the full 1 Gbps speed. With Wifi it is very unlikely to get the advertised router wifi speed.
