Bought New LG LW4500
new mumbai
Friends after a long search I finally purchased LW4500 3d LED TV .
I wish to check some 3d videos , can any one give me a link to download good quality 3d videos ?
I also wish to upload pics of my TV , can anyone tell me how to upload direct pics in thread?
Thanks !
Thanks !
share your experiance of decision making and qualty of the product.You not said anything @ size and price,skims,free guddies etc.
Size 42 inch
Price - 64000 (under exchange scheme)
Scratch Card
4 glasses
8 gb usb drive with 3d movie.
PQ is awesome ... frm black level to contrast everything seems fine on HD video .
SD video will be checked later.
3d is best if compared with samsung or Panny plasma's ...
absolutely flicker free .... no headache even after 1 hour .
Sound is quality is also good.
My queries -
1) Plz suggest me best color and all settings for this 3d tv.
2)there is loadshedding problem in my area , do i need a stabilizer for longer life of TV ?
3)Why does it plays some .mkv files and some do not open ?
sorry for blurred pics .. will post clear pics sooon!! :)
He ,
that is real cool
The problem is that this new model and most of the frends are intarested in lw6500 or5700 series because of their personel views ex.flicare free and more motion hearze ( 100 or 200) , more suppert through usb etc.
I realy surprice why you brought this model,their is hardly 5-7 K difference between higher version.
I sajjest if it not very late you can upgrade to 42lw5700
He ,
that is real cool
There were 2 models in reliance digital , 4500 and 5700, i auditioned them both with HD content and 3d content, and there was ZERO difference , both of them have flicker free 3d vision , only 5700 had some point percen more contrast .. tats all , the price difference is due to smart tv , and i dont need smart tv cause i dont wish to use internet with this tv. If you dont need a smart tv i will suggest you all to go for this tv , passive 3d , HD and superb SD and less power consumption !!!
Congratulations on your purchase of new television, which I am going to buy LG 32lw4500 after 2 days
but i need to ask you
can i see the subtitle with films which i see by usb
separated subtitle srt sub txt which we bring it from internet
please answer me
it is important to me
do i need a stabilizer for my 3d led tv?
Ideal case would be that you use a voltage stabilizer and a surge protector.
In most cases, people use a surge protector in the form of a high quality power extender (Belkin Gold or equivalent) - that should more or less provide the much needed softening.
If you have very high voltage fluctuations in your locality, it would be good to have a stabilizer.
My 2 cents.
attaching comparison except DNLA certificate and more usb support all things are nominal to me too
What you did is absolutely right. This TV is everything that top end TVs are except for Smart TV, so the right choice if you do not wish to use internet.
BTW, what's you viewing distance? Do you think you don't need a 47" TV? I am confused myself between what to buy 42 or 47?
Optimum HDTV viewing distance - Wikipedia, the free encyclopedia
chk this
calulater in this page
1080p Does Matter – Here’s When (Screen Size vs. Viewing Distance vs. Resolution) | CarltonBale.com
and
http://www.hifivision.com/newreply.php?do=newreply&p=296315
c
neeraj did you chk the rates for the 47" LW 4500 also...wud be great if you cud tell!!!
