Hi Guys,
After going through the pictures\threads of Vinay,Mdharan, Purna, Premblr and many others got really motivated and I am also planning to setup a dedicated home theater room.
Mine is an Independent Duplex house with 4 Bed rooms. Now I am in the dilemma whether to convert one of the guest rooms which is 20ft by 13 in dimensions and with 5 feet gone for the bathroom will have a clear space of 15ft by 13ft for the dedicated room.
Alternatively I can construct a new dedicated room in the terrace with dimensions in the range of 24ft by 15ft.
Converting the guest room:
Pros:
1.It is ready and just need to do the acoustic treatment.
2.Easy and regular access as currently I goto the terrace hardly once in a month.
Cons:
1.Fixed and limited dimensions.
2.Need to do lot of wirings for the 5.1 or 7.1 setup and literally not possible to
go beyond 7.1.
Construcing a dedicated room in terrace:
Pros:
1.If planned well with the help of our forum members will turn out to be an excellent one.
2.Can construct a curved wall similar to Mdharan's setup.
Cons:
1.Budget will needs to be stretched as the construction cost is huge now.
2.Not sure about the approval process for constructing a room in the 2nd floor.
Can I just to do the acoustic treatment for the guestroom now, by installing the acoustic panels and use it for 2- 3 years and then reuse the same when constructing a new room in the terrace?
The above option if it can be executed seems to be the most cost effective.
Now coming to the components:
Already Purchased:
Projector - Epson Tw 8100
Blu ray player - Panasonic BDP 220
Both the above were recently purchased based on the feedback from our esteemed forum members.
APC 1100V - UPs for projector
Pending items to be purchased:
Screen- Curved screen seems to be really nice but comes in above 35K need to check for any good quality low priced model.
And for a 13 feet wall can I go for a 150" projection or 135" would be better?
Planning to add a Denon AVR with Polk speakers combo but will need to audition them before. I will shortly post the pictures of the room.
Please provide your valuable inputs so I could decide upon the room and start the work quickly.
Pros:
Cons:
go beyond 7.1.
Pros:
Cons:
Already Purchased:
