Good! Just check symmetry of your PS.That is not a problem. Cheers.Typo: -0.65mV, NOT -65mV!!!
Lovely build and a good review by Jaibir.
I think you mean Joshua - jls001
+1
Sachin
Now enjoying the double decker
Will reserve critical judgement for future to allow the new board some time to burn in.
I have been listening to the double decker for a few days now. I honestly don't hear an improvement over a single DCB1. May be improvements are system dependent?
You can add simple switch for selection.@Om/Sachin: can we use something like a DPDT as a passive two-way source selector for the DCB1? Having only one source is impractical as I switch between two turntables and a CP player. I can compromise to one TT and one CDP.
Do you think it will compromise the sonics? FWIW, I use a DPDT on the B1 to select Source 1 or 2. I do plan to complete the source selector kit someday (got ages ago from Sachin)
I have Pass B1 with 3 input selectors and remote control for volume.
Now I am planning to build DCB1 myself. Can i remove the existing circuit of my PassB1 and add direct coupled circuit? Please suggest, as I want to keep the facility of remote and input selector as it is.
Remote control is extremely cool.
I want one
How did you implement it? Is it available as a kit somewhere?
You should be able to remove your existing B1 board and install DCB1 with the existing setup. Afterall, the B1 with two inputs is made into a single input device when we want to use an outboard source selector (by shorting one pair of the source selection links on the B1 board).
Yes..trafo should be replaced . i remember, you pointed out the same at that time.dheerajin, you can replace your B1, with DCB1. But IMO you will need good dual power supply like we build for this forum. Because B1 has single 18-14V PS, DCB1 needs dual +/-10V PS. As far as I remember, you box does not have r-core and OPS. But you have separately implemented that. So point to be noted.
May we get one from Mr.Bajaj, Norge.Remote control is extremely cool.
I want one
I understand your problem. But you know I kept it simple for DIY as many people can get source selectors from online and already having. You can use any good quality sealed DPDT switch.@Om/Sachin: can we use something like a DPDT as a passive two-way source selector for the DCB1? Having only one source is impractical as I switch between two turntables and a CP player. I can compromise to one TT and one CDP.
As far as you keep wires flowing in one direction and short in length, it won't affect sonics.Do you think it will compromise the sonics? FWIW, I use a DPDT on the B1 to select Source 1 or 2. I do plan to complete the source selector kit someday (got ages ago from Sachin)
This has many duplicates in market and easily develop loose contact. Try to get original. Also mounting these switches and finding knob over it is one more headache. That is why I prefer simple lever type toggle switch.You can add simple switch for selection.
http://www.electronix.com/images/34-409.jpg
