DIY Enclosure/Cabinet for PowerAmp & PreAmp
Here is the updated drawing for the mounting holes. I would really appreciate if someone can crosscheck and confirm the dimensions with the actual PCB/R-Core.
Thanks,
Bibin
Updated List
Pass B1 Cabinet GB members
1) apk (Rs. 3465 + Shipping)
a. need all accessories and hardware
Payment Received Rs.2600/-
2) mbhangui (Rs. 3465 + Shipping)
Payment Received Rs.3400/-
3) thecoolestone (Rs. 3465 + Shipping)
Payment Received Rs.3000/-
4) rohitmusic (Rs. 3485 + (Dif. of Acrylic & wooden panel) +Shipping)
a. Wooden Front Panel
b. Please exclude power cable from accessories
c. Please keep 5 source selection option - CD, TUNER, TV, PHONO, AUX
5) ruenigma (Rs. 3465 + Shipping)
Payment Received Rs.3465/-
6) Santy (Rs. 3425 + Shipping)
a. 42mm cut for volumeSource selector knobs
b. need all accessories and hardware except the DC terminals
c. Don't require the DC terminals on the back panel
Payment Received Rs.2700/-
7) keith_correa (Rs. 3224 + (Dif. of Acrylic & wooden panel) +Shipping)
a. Back plate Need 5 source inputs - PC, CD, TUNER, TV, AUX
b. Front plate Need 5 indicatorslabels for source - PC, CD, TUNER, TV, AUX
c. Wooden Front Panel
Hardware & Connectors (Cost 325)
a. Elcom - Power Jack Chassis Mount with 10A Fuse Holder - Qty 1
b. Rocker Switch - Qty 1
c. Female Spade Receptacle Connectors - Qty 10
d. All Hardware
Tools (Cost 499)
a. Soldron - 25W Soldering Iron
b. Soldron - Soldering Iron Bit
c. Soldron - Soldering Iron Stand
d. Multitec - Adjustable Wire Stripper
Payment Received Rs.3224/-
8) santnai (Rs. 2725 + Shipping)
b. Source Label Phono,CD,Tuner,Aux
c. Don't require Power Cable and RCA
d. Don't require the DC terminals on the back panel, instead a single 10mm hole with label Ground.
Payment Received Rs.2000/-
9) vktarun (Rs. 3670 + Shipping)
a. Need all accessories and hardware
b. a. ELCOM power socket with built-in EMIRFI filter for me instead of the regular ELCOM power socket
Payment Received Rs.3670/-
10) Hydra(Rs. 3630)
a. Cut for VolumeSource selector knobs of size 38mm.
b. Source Labels 1, 2, 3, 4
c. I don't require the DC terminals on the back panel.
d. Full accessories Power, Signal & Hardware
e. ELCOM power socket with built-in EMIRFI filter instead of the regular ELCOM power socket
Payment Received Rs.3630/-
11) jls001(Rs. 3465 + Shipping)
12) hifipal4all (Rs. 3545 + (Dif. of Acrylic & wooden panel) + Shipping)
a. Back plate Need 5 source inputs - INP1, INP2, INP3, INP4, INP5 AND 2 sets of ouputs - OUT1, OUT2
b. Front plate Need 5 indicatorslabels for source - INP1, INP2, INP3, INP4, INP5
d. Don't require the DC terminals on the back panel AND Banana Socket Connectors
e. Need all accessories and hardware
13) gvenu (Rs. 18485.00+ Shipping)
1x B1 Cabinet - Rs. 3465.00 (Including all accessories and hardware)
2x Power Amp Cabinet without heat sink(WxDxH in inches :17.25 x 17 x 8) - Rs. 15020.00 (Including all accessories and hardware)
Accessories and Hardware for power amp:
1. BINDING POST TERMINAL (GOLD PLATED) SCREW TYPE & TOUCH PROOF x 4
2. Gold Plated RCA x 2
3. Power socket x 1
4. Power Cable x 1
5. Power Switch x 1
6. SS Allen head Bolts and Nuts x 4
7. Plastic/Rubber bush x 4
8. 3x15mm Screw x 12
9. 3x10mm Bolt and Nut x12
10. 12 AWG Teflon wire Red, Black, Blue - 2m each
11. 3 core Teflon shield wire - 1m
Note For Wooden Front Panels i will update the cost after completing the work.
B1 Cabinet and Acrylic panel work has started and no more modifications here after.
Thanks,
Bibin
Hi !
The Prototypes of the Knobs are now ready. These are made in two different materials. Black POM & Black PET. The samples are made plain and knurled in each grade. Now you need to select one. Pl. let me know who should these be sent to for an approval and selection.
Jayant
Hi !
Jayant
Jayant, The knobs are awesome.....great job....
Hi !
Jayant
Jayant - they are Awesome!!!!!! Would it be possible for you to send them to me in Mumbai?
Thanks Guys ! Good you like them.
Keith,
I can courier them to Mumbai or if you can collect from Vile-Parle, I can can carry them on 10/02. You will need to take a call on the extended Stem of one of the Rotary Switches as well. So you need both the Switches as well as Knobs or do the Switches go back to Sachu ?
Jayant
Keith,
Jayant
Collecting from Vile Parle on the 10th is no problem. If I cannot make it, I can send someone to collect them. I have the switches with me. If you give me Sachin's switches too, I can send them back to him - can save you the trouble/effort of doing that.
Keith,
I will carry the Knobs along with Switches to Mumbai. Appreciate your offer to return back the Switches to Sachin for me. Pl. check your PM.
Jayant
Updated for folks who want the knobs
Color: Black
Material: TBD
Shaft diameter as measured by Jayant from samples sent to him by Sachin:
Potentiometer: 6.3mm
Selector: 6.0mm​
Folks who want knobs - so far:
  • keith_correa [7 pot knobs + 5 selector knobs]
  • jls001 [1 pot knob + 1 selector knob]
  • hydra [1 pot knob + 1 selector knob]
  • apk [1 pot knob + 1 selector knob]
  • TheCoolestOne [4 pot knobs + 4 selector knobs]
  • mbhangui [1 pot knob + 1 selector knob]
  • vktarun [1 pot knob + 1 selector knob]
  • ruenigma [1 pot knob + 1 selector knob]
Hi Kieth, I'm also keen on the knobs GB. Need one selector knob and one pot knob.
Jaibir
The cabinets works are completed today and the acrylic panels are also ready. The wooden panels will be ready by end of day tomorrow.
Now packing and shipping, hope Wednesday or Thursday on-wards i can start the shipping if i get the packing boxes ready.
If any of you guys are interested in combined shipping please let me know.
Will post few photo tomorrow... i am really tired and going to have :beer: :cheers:
Thanks,
Bibin
Color: Black
Material: TBD​
Selector: 6.0mm
  • apk [2 pot knobs + 2 selector knobs]
  • jai1611 [1 pot knob + 1 selector knob]
Keith, I would like to get the knobs too. I have updated the list below.
baswamin [2 pot knobs + 1 selector knob]
Keith, 1+1 updated the list below.
rohitmusic [1 pot knob + 1 selector knob]
sann [1 pot knob + 1 selector knob]
