DIY Enclosure/Cabinet for PowerAmp & PreAmp
Will group shipping help reduce shipping costs, as there seem to be multiple members per location.
(We had done this for Pass B1 kit so just asking)
Though its worth more than it, honestly, some of us were expecting the price for the cabinet might come down since its a group buy.
bibin,
I do not need DC terminals and I wish there's no hole drilled for it. But still wish to know what purpose exactly it solves? For running on battery or attaching to a better power supply?
bibin,
Hi Santy,
The sheet metal workshop guy has agreed to give some discount on the final amount. But i don't think it will be a huge discount, because he mentioned like he can give 20% discount for 50+ qty.
I will remove those DC terminals and holes and label for the same. I don't think it will make any difference. I have enough stock of Li-Ion battery with me so decided to power it with that.
Thanks,
Bibin
Bibin, if its not too much trouble, could you include me also in the Pass B1 Cab Group Buy as follows:
hydra
a. Cut for Volume/Source selector knobs of size 38mm.
b. Source Labels: 1, 2, 3, 4
c. I don't require the DC terminals on the back panel.
d. Full accessories: Power, Signal & Hardware
I'll pick up the cab from you. I'm from Kochi.
Thanks! :)
hydra
Thanks! :)
Hi Hydra (Anup right?)
Sure i will add and the modifications can be done.
Thanks,
Bibin
@bibin: if it's not too late, please include me too with complete accessories and hardware.
Also, do PM me your bank details for payment.
Updated List:
Pass B1 Cabinet GB members
1) apk (Rs. 3465 + Shipping)
a. need all accessories and hardware
2) mbhangui (Rs. 3465 + Shipping)
3) thecoolestone (Rs. 3465 + Shipping)
4) rohitmusic (Rs. 3465 + (Dif. of Acrylic & wooden panel) +Shipping)
a. Wooden Front Panel
b. need all accessories and hardware
5) ruenigma (Rs. 2400 + Shipping)
6) Santy (Rs. 3425 + Shipping)
a. 42mm cut for volume/Source selector knobs
b. need all accessories and hardware except the DC terminals
c. Don't require the DC terminals on the back panel
7) keith_correa (Rs. 3224 + (Dif. of Acrylic & wooden panel) +Shipping)
a. Back plate: Need 5 source inputs - PC, CD, TUNER, TV, AUX
b. Front plate: Need 5 indicators/labels for source - PC, CD, TUNER, TV, AUX
c. Wooden Front Panel
Hardware & Connectors (Cost: 325)
a. Elcom - Power Jack Chassis Mount with 10A Fuse Holder - Qty: 1
b. Rocker Switch - Qty: 1
c. Female Spade Receptacle Connectors - Qty: 10
d. All Hardware
Tools (Cost: 499)
a. Soldron - 25W Soldering Iron
b. Soldron - Soldering Iron Bit
c. Soldron - Soldering Iron Stand
d. Multitec - Adjustable Wire Stripper
8) santnai (Rs. 2725 + Shipping)
b. Source Label: Phono,CD,Tuner,Aux
c. Don't require Power Cable and RCA
d. Don't require the DC terminals on the back panel, instead a single 10mm hole with label "Ground".
9) vktarun (Rs. 3465 + Shipping)
a. Need all accessories and hardware
10) Hydra(Rs. 3630)
e. ELCOM power socket with built-in EMI/RFI filter instead of the regular ELCOM power socket
11) jls001(Rs. 3465 + Shipping)
12) hifipal4all (Rs. 3545 + Shipping)
b. Don't require the DC terminals on the back panel, instead one more output so total 4 inputs and 2 outputs.
Note: For Wooden Front Panels i will update the cost after completing the work.
Correct me if there is any mistake.
Thanks,
Bibin
^^that is huge effort! Preparing that list is too time consuming, hats off!
Bibin you deserve :clapping:
Thank you Mishraji.....You are more experienced and you know it better. A real time eater and very difficult to manage.
Next challenge is the customization, almost all panels need some sort of modifications.....:sad:
Thanks,
Bibin
Bipin,
Very nice compilation of same. Good to see your dedication on updating/ Like your cabinet you are also professional.. Also very nice support from your end to encourage DIY along with Sachu /Omishra/ Doc.
I have seen some guys just for name sake only tell they do DIY everything..But never seen their efforts in papers. But you guys rock.:cool:
Err Bibin, I need all accessories and hardware. My bad I did not see this thread in the meantime as I was out. Please update it with all accessories and hardware. Will transfer the remaining funds tomorrow :)
Can some one please help me in locating the post where all the Accessories and Hardware supplied along with the B1 cabinet is listed. I tried but could not get it:sad:
Vipin
