DIY Enclosure/Cabinet for PowerAmp & PreAmp
Jayant, this POM, does it have a matt or gloss surface? Also, is it a soft plastic - meaning if drawn into a thin rod, if bent, will it crack or give?
Keith,
POM gives a glossy fine finish. It is not soft but is tough. It is not brittle either. So need not be concerned about developing cracks.
We machine components using the same material for some fastidious Customers in Healthcare Industry and believe me it appears like a work of art !
One could also consider Black PET material which is harder that POM and yields more matt finish but also more brittle.
Jayant
<snip>and believe me it appears like a work of art !<snip>
Why do you think you came to mind when I was wondering about machining the knobs? The ports on your MLTL was exactly that - a work of art :)
OK, then we will have to take a call on whether we want a gloss or matt finish.
I vote for MATT!
Jayant, how about using Nylon [the same as your ports] - I like the feel of Nylon :D I guess even fingernails would scratch it, right?
I have received the dimensions of the PCB's from Sachin. The drawing is based on that dimensions. If somebody can provide me the mounting hole dimensions of the transformer i can include that too.
Please let me know if it requires any change in the arrangement of the PCBs.
Thanks,
Bibin
Thanks,
Bibin
Bibin, Great effort!
Please move that phono stage to extreme right, away from transformer and power supply. Also source selector near the input RCA, Other boards looks correct to me. [Even position of r-core and PS board could be exchanged.]
Last year I drawn diagrams for magma. it is here. Please see these has marking for r-core transformer which is same order now repeated for us.
It seems 60mmX70mm and 25mm space lengthwise and 10-12mm sidewise for its body and space for IEC socket or any other nearby connection.
Edit: just now I verified it and its correct. Also hole could be 4mm
Jayant i am not an expert to create an engineering drawing of the knob. If we provide the dimensions, will that be useful. The outer dia of the flange is 37mm i think and the shft hole is 6 mm. I can sent you an accurate measurement today evening after reaching home.
Bibin, any update on the dimensions of the knobs that you have?
Bibin,
If you can send me a mating part with the shaft ( Potentiometer ? ), it will be easier to make a sample. We may want to have a press fit on the shaft.
Jayant
I think Sachin is providing the potentiometer to the GB members. The pot i have used is an imported one with round shaft (dia more than 6mm).
@Sachin,
Can you please provide the details of the Pot?
Thanks,
Bibin
Sachin,
Is it possible for you to suggest the ID of the mating hole to mount on the shaft as well as the grub screw( if provided ) to secure the Knob on the shaft ? Alternately pl. send me a part so that the details can be engineered.
Jayant
PM me your shipping address.I will send you POT tomorrow.Do you also need Rotary switch,I am providing with input selector.It looks similar to this http://diyaudiocart.com/Rotary-Switch-1-Pole-12-Position
Sachin
I think a slightly oversized dia. on the knob than the shaft dia. maybe fine. Wrapping teflon tape over the shaft should ensure a nice fit.
I am closing the GB for B1 cabinet and here is the final list of members and cost break up:
Pass B1 Cabinet GB members
Cabinet, Front and Back Panel (Cost Rs.2400)
1) apk (Rs. 3465 + Shipping)
a. need all accessories and hardware
2) mbhangui (Rs. 3465 + Shipping)
3) thecoolestone (Rs. 2400 + Shipping)
4) rohitmusic (Rs. 2400 + (Dif. of Acrylic & wooden panel) +Shipping)
a. Wooden Front Panel
5) ruenigma (Rs. 2400 + Shipping)
6) denom (Rs. 2400 + Shipping)
7) Santy (Rs. 3465 + Shipping)
a. 42mm cut for volume/Source selector knobs
b. need all accessories and hardware
8) keith_correa (Rs. 2400 + (Dif. of Acrylic & wooden panel) +Shipping)
9) santnai (Rs. 2725 + Shipping)
b. Source Label: Phono,CD,Tuner,Aux
c. Don't require Power Cable and RCA
d. Don't require the DC terminals on the back panel, instead a single 10mm hole with label "Ground".
10) hifipal4all (Rs. 3545 + Shipping)
a. Need all accessories and hardware
b. Don't require the DC terminals on the back panel, instead one more output so total 4 inputs and 2 outputs.
Note: For Wooden Front Panels i will update the cost after completing the work.
Accessories
Power (Cost: 255.00)
1. Elcom - Power Jack Chassis Mount with 10A Fuse Holder
Qty: 1
2. AC Power Cord Black
Qty: 1
AC Power Cord Black
3. Rocker Switch
Qty: 1
Rocker Switch - ( RSF11 )
4. BANANA SOCKET CONNECTOR (FLAME RETARDANT)
Qty: Pair (Red & Black)
MX 4 mm BANANA SOCKET CONNECTOR (FLAME RETARDANT) - PAIR
5. Female Spade Receptacle Connectors
Qty: 10
FDD 2-250 Insulated Wire Female Spade Receptacle Connectors - 10 Pcs.
Signal (Cost: 120 x 5 = 600)
1. RCA CONNECTOR CHASSIS (GOLD PLATED)
Qty: 5 Pair (5 Red and 5 Black)
MX RCA CONNECTOR CHASSIS (GOLD PLATED) - PAIR
Hardware (Cost: 210)
1. Hex Allen Bolt and Nut - 4mm SS
Qty: 4
Cost: 60.00
2. 3x10mm Philips Flanged Head - 12 Pcs
Cost: 10
3.3x18mm Philips Flanged Head - 24 Pcs.
Cost: 22.00
4. 3mm Hex Nut - 32 Pcs.
3mm Hex Nut - 24 Pcs.
Cost: 15.00
5. 5x6mm Nut and Bolt with washer (For mounting Transformer)
Qty: 4
Cost :7
6. Spacer 12mm SS - 24 Pcs.
Spacer - 12mm SS
Cost: 84.00
7. 4x6.5mm Philips Dome Head - Self Screw - 24 Pcs
4x6.5mm Philips Dome Head - Self Screw - 24 Pcs.
Cost: 12
8. Rubber/Plastic Bush (Foot)
Qty: 4
Cost: Update later.
Please correct me if there is any mistake and i request all GB members to PM me your shipping address along with Email ID and contact no.
Thanks,
Bibin
Bibin,
This is great news. Can you include me for the Accesories (Signal + Power + Hardware) also.
Please do let me now my revised cost.
Bibin,
Updated List:
3) thecoolestone (Rs. 3465 + Shipping)
Accessories
Qty: 1
Qty: 1
AC Power Cord
Black
3. Rocker Switch
Qty: 1
MX
Qty: 10
MX RCA
Qty: 4
Cost: 60.00
Cost: 10
Cost: 22.00
Cost: 15.00
Qty: 4
Cost :7
Spacer - 12mm SS
Cost: 84.00
4x6.5mm
Cost: 12
Qty: 4
Cost: Update later.
Thanks,
Bibin
Hi Bibin, Keith, Sachin,
I received the two Switches from Sachin. The Knob dimensions are:
1. 6.3 Dia x 42.2 mm
2. 6.0 Dia x 15.7 mm
Any changes you would want on the Knob ?
Jayant
Jayant, I'm fine with these dims.
BTW, which dia. is for the potentiometer and which is for the source selector?
Guys who are interested in the knobs - please respond to Jayant's query.
Updated List:
4) rohitmusic (Rs. 3465 + (Dif. of Acrylic & wooden panel) +Shipping)
Accessories
Qty: 1
Qty: 1
AC Power Cord Black
3. Rocker Switch
Qty: 1
Qty: 10
Qty: 4
Cost: 60.00
Cost: 10
Cost: 22.00
Cost: 15.00
Qty: 4
Cost :7
Spacer - 12mm SS
Cost: 84.00
Cost: 12
Qty: 4
Cost: Update later.
Thanks,
Bibin
