kroyin, Yes that will be difficult for heavy double thick PCB. These are double sided through hole PCBs. Even holes are having inner layer plated of copper pipe.After considerable difficulty put the JFETS in (8mA to replace 10mA)
not sure whether I'll able to change a faulty trimpot
There is a trick to remove old parts. First make all leads straight inline to hole (if required melt the solder on existing pad). Apply more soldering material over all pads of trimpot and keep it melted while pulling the part from downside. Do this quickly within 5-6 sec. After that clean hole individually.
If the part is faulty then cut the leads carefully and individually start removing remaining wire from holes.
