Hi Vortex,
I have tried with Poweriso it doesn't work. I have downlaoded audacity it looks preety cool and I can identify the three songs in the wav file. The file is actually Edouard_Lalo_Cello_Concerto_in_D_Minor. Rings any bell???
Btw I have my pc fianlly up and running with a new mobo Asus M2N68-AMPLUS Motherboard ( The guy couldn't get Asus M3N78-EM 8GB DDR2 told me not available in Calcutta) and AMD Athlon II X2 240 2.8GHz processor 3 gb of ram. I thought if I go for a dedicated sound card and a graphics card this mother board should do the job. Otherwise my pc would have been delayed by another week.Another problem is ITDEPOT doesn't have any stock of Asus xonar essence STX sound card. Have to look for a new vendor to get them. Can you please suggest me a decent video card which can bring microsoft flight simulator delux edition to full glory.Today I played some music from my pc onboard sound card using foobar the music sounded ok not too bad but nothing special either. I hope asus will improve things considerably.
Mahiruha - I guess then that you have figured out a solution to your problem
About the motherboard, I would have waited and gone for the 780G chipset. That has a decent onboard graphics chip and you might want to try and see how far you got with the Flight simulator game.
I wont recommend using a dedicated graphics card for a Music PC. It increases heat and noise and does not improve the music performance. But if you absolutely need to play games on it, why not try and see if the onboad graphics chip with the 780G chipset board will allow you to do that? If not, then we can look at other options.
