Yep. Same problem here. I think this has also happened with Zee Studio HD a few days ago. Havent checked if that be has been fixed.
I also found similar problem with Zee studio HD in Mumbai..
Is any one facing problem with Star Plus HD when dolby is enabled? There is no sound when dolby is enabled but works fine when PCM is enabled. This is not an issue with other HD channels.
Hathway is planning to add 10 more HD channels to take the count to 30 after all the analogue channels have been switched off.
I guess it is possible. Buy directly from Hathway office. You will just have to pay Rs4500 if you buy from them. This includes HD box + 1 year HD subscription. You will need to pay your LCO like how you are paying now for SD channels
