Hathway goes HD in Bangalore??
Just saw the message on HD box that Zee turner on alacarte from 1st Aug, I dont know which are the channels in Zee turner. Any idea??
Compared to HD, SD channels look terrible. This is even more evident in sports channels where details boost the entire experience. I wonder when Hathway (and everyone else) will start treating HD and SD at the same level.
Hathway seem to be trying to put nails in their own coffin by keeping customers in the dark about details on channels. Wonder what the rest of their customer base is thinking...
MTV Indies SD has been added in Bangalore. It looks like a true HD channel judging by the aspect ratio.
Saw a few posts on another forum showing Animal Planet HD and TLC HD on Dish TV. Once the highest, it looks like Hathway are now lagging behind in HD channel additions.
Yes Recv mssge for Zee Turner for La Carta. Dunno if the zee group Hd channels will be effected or not.
Zee is All Zee channels
Turner Cartoon network ,CNN pogo HBO WB Etc
The channels included in the list are Zee TV, Zee Cinema, Zee Marathi, Zee News, Zee Caf, Zee Studio, Zee Punjab Haryana Himachal, Zee Bangla, Zee Business, Zee Salaam, ETC, Zing, Zee Jagran, Zee Talkies, Zee 24 Taas, Zee Smile, Zee Kannada, Zee Telugu, Zee Kalinga, Zee Classic, Zee Action, Zee Premier, 9X, Zee Madhya Pradesh Chattisgarh, Zee Bangla Cinema, Zee Marudhara, Zee Tamil, & Pictures, Zee Anmol, Zee Q, Zee Khana Khazana, Zee Sangam, 24 Ghante, Zindagi, Zee TV HD, Zee Cinema HD and Zee Studio HD from the Zee stable as well as CNN International, Cartoon Network, HBO, POGO and WB of Turner International India.
Just checked, all Zee channels are blocked except HD channels!!!!!
How to pay the same monthly price after blocking all those channels. This is unacceptable for the viewers who bought STB from Hathway.
I think it won't be too long before HD channels are blocked! Samething happened with Star Sports HD channels too.
Its really a Joke, so many cable operators and DTH operators and uses there own STB and user as to pay the price. Why can't they use a single STB so that user could migrate to other operator and save the STB.
No body cares for these electronic wastages (e-waste)!!!!!
n its order today, TDSAT has asked Taj Television to restore the channel signals. Also, starting August, until any further order from the regulator, Zee and Turner channels will be available on a la carte only on Hathway in the DAS I and II areas.
As for the pending payment from April to July, the MSO will pay Rs 21.60 per set top box to the broadcaster. The payment has to be made on an immediate basis, the source reveals.
Hathway on its part is also working out packages which will ensure that the consumer is not burdened with heavy cable bills.
Read more here: Hathway to provide Zee, Turner channels on a la carte | Indian Television Dot Com
I have a peculiar problem and I'm unable to pinpoint the reason behind it. Please post here if you have any thoughts...
There seems to be signal reception problems in my HD STB because channels are appearing only for a few minutes and then the "Technical Problem" message appears. This keeps alternating every few seconds/minutes.
The strange part is that different channels are affected in different ways. For ex: ETV Kannada is 'stable' for about 5-8 mins whereas BBC News is stable for barely 1 min! In the past, I've seen all channels having equal distortion but never like this.
I have internal wiring in my apartment for cable TV and my cable guy said that it could due to the degradation of the wires and consequent loss in quality. I'm a bit skeptical on this as its only about a 15 yr old building but I'll need to look into it.
I was of the opinion that something has gone wrong with the amplifier. The cable guy said thats not the cause but I'll have to look into this possibility as well.
I realize that this is quite a long post, but any thoughts would be appreciated!
I can think of only 2 reasons. 1) STB has some issue and/or 2) Cabling issue.
You can ask your cable operator to check the STB at his place to eliminate the reason of STB being faulty.
You can also ask the cable operator to check the signal level at STB end as well as at the place which enters your building. If the signal levels are different then internal wiring is probably faulty.
