allajunaki
42v20 has been discontinued, so its quite difficult to get one.
Since you said no for X30, you may consider ST30. PQ is up there with v20, and tons of features to boot
. Costs ~70k and comes with one pair of 3d glasses (one pair = 1 glass, in order to avoid confusions
This is a 2011 NeoPDP Infinite Black Pro panel.
Also for 13 ft, you can easily go for 50inches. 50v20 is just 80k, and for that price, nothing comes even remotely close in VFM department
I am pretty lost. Decided on the v20 but its discontinued and not getting a fresh piece. I have decided to go for a plasma. My usage would be cable with stb - sd & hd movies. Saw the x30d & the v20 side by side and x30 is definetly a no. Any other suggestions that i can go and check as most retailers not stocking plasma's.
Size - 42 "
Viewing Distance - 13 ft
