Beast_of_burden
Hi All,
I decided to register as I need help with building front horns for a pair of Lowther DX-3s that I own. I am pleasantly surprised at the active community of audiophiles here. I have been a DIYer for a long time. Have built Fostex BLH, lowthers in open baffle, lowthers in Tp1 Isis front horn, an old 3 way design with cheap locally available drivers. It has been an interesting journey.
Revelatory moments in that journey:
1. Listening to Riders on the Storm played on honey dripper tube setup(dont hav details of that setup, but guessing it was EL34 based) at the Analog room, Bay area. Vapour trails on each note, wonderful nearfield system. Picked our jaws off the floor listening to that soundstage - holographic and utterly hypnotic.
2. Wright 2A3 + DEQ2496 + ML Dynamo + Klipsch Rb 61 + CJ PA10 + heavily damped room = gloriously balanced full range music, silky, seductive, brilliant! No vapour trails, but the treble rose and fell like a waterfall. All budget components to boot.
3. Lowther DX3 in DIY TP1 Isis front horn paired with an Almarro EL84. Whoa!
Low points:
1. Fostex FE206 in FE208 BLH. Thats right, i built them but they havent lived up to my expectations. Considering throwing the big heavy boxes and putting the drivers instead in an infinite baffle enclosure along with Fostex woofers that I also own. will make a nice shouty PA system for sure. But then all full rangers belong in a front horn, my POV anyway. Ended BLH experiments.
2. Lowther DX3s and Fostex 305s in open baffle, screechy:lol: Much better after doubling the baffle size with foldable ears, but completely impractical at 5 ft wide.
3. Fostex 12# woofers in DIY H frames. yikes! End of open baffle experiments.
Right now too busy at work. dont get enough time to listen let alone build anything. The Fostex BLH isnt really such a great speaker. But I need to bring the lowthers back to life in those front horns. Hornresp has eluded me, I need help in understanding / simulating a simple 493mm exponential horn(TP1 ISis front horn). There are good things said about the Oris horns, maybe i should build clones considering it is rather difficult and expensive to source them here.My speaker building days are probably over, need help with resources who can execute the designs.
Low points:
