but ran out of skill after I built the front horns.
Purely on an experimental basis I started out to build the mighty Lowther Tp1 ISis, but ran out of skill after I built the front horns. I will post that experience separately. The Lowthers are now back in their boxes waiting for another bout of inspiration. I will most likely build the front horns as satellite units and pair them with a pair of Fostex 12" FW305s. may have to attenuate the lowthers by about 3-6 db, but that is not a bad thing if I succeed in bringing the sound into balance.
Great to see another horn guy on the forum.
If you would like to pursue the Lowther TP1 build you should contact Anilva on the forum.He has the services of a really good carpenter,who will be able to build your Lowther cabinets.
You might find this link useful,if you decide to go with the Fostex woofers and Lowther combination.
http://audioroundtable.com/forum/pdf.php?th=9326&S=0a4a3bb689a7c0bb0abdff77c460f9be
Rajiv
Anil lives in Bangalore but is out of town until early August, very interesting pewrson to meet up with, esp regarding horns and diy.
Also very curious as to how the BLHs he's built sound vs mine.
Sometime it is very difficult to judge a DIY speaker in absolute terms, an added point of
reference definitely helps.
Really good to have another solid DIYer in our midst.
Your speakers look excellent.
It might be interesting if you could compare SoulForged's
FE206 BiBs with your BLH design cabinet.
Before I built the Sachikos, I seriously considered going with the
208 Fostex design as it was highly recommended by ScottMoose
and others.
I understand the FE-207 could use help from a supertweeter, but
perhaps even the FE-206 could benefit from it too.
Very true. I felt the same too after building mine.
Personally, I am satisfied with the FE206 in the Sachikos, but
to be fair, my "budget" setup in a bedroom, is not really
acoustically ideal, nor do I have very good ears.
You built the massive Sachikos, amazing. I would love to hear them. What amplification are you using?
My BLH speakers sound pretty good with a T-amp, plenty of authority in the bass with just 3-4 watts. The biggest lesson I've learnt from this project is that BLH designs sound best when played loud and consequently not quite suitable for nearfield listening. The problem isnt with the speaker, it is with the application.
The Sachikos are here -
https://picasaweb.google.com/prasadb/SachikoSingleDriverSpeakers
Other projects, incl my amps are here.
Picasa Web Albums - Prasad
The Sachikos too sound better played loud.
However, even a low powered 6B4G Get*Set*Go SET amp can drive
them to uncomfortably loud levels.
I also have a KT-77 Push-pull amp, but the SET has displaced it
as the primary amp, as I feel it is more balanced, and musical.
Can you provide more details of the 6B4G, it looks like a largish tube but not quite as big as the 2A3. Are these readily available?
Are you an electrical engineer or something?
I would find find a project such as this extremely intimidating, my soldering skills are BS. The most I have ever done is replace the coupling caps in my Almarro A205 which is a single ended pentode. Interestingly enough, my open baffle and TP1 Isis experiments were all done in Hyderabad. The lowthers are still in Hyderbad. Most of the tools and unfinished speaker projects are still lying around there. I visit Hyderabad often enough, we should definitely meet.
