arnab.techcool
I am thinking about....How it will perform after connecting the sub to my Sony System....The sub has no crossover setting...It has only the the volume knob....Will it work fine with my Sony System? Please suggest
you need some control to cut off frequencies either to the mains or the sub. depending how low thw main speakers go, say 80hz then they both will emit 80hz to 160hz at the same time, booming the hell out of anything you play.If you can insert a crossover between the system and the sub it might work. either DIY or buy one.
check if the Sony has a crossover function. don't think equalizer will only effect the mains or the sub output.
Take a look at this, came across this on quikr. I think it will match your setup (aesthetic) & requirement too i.e crossover settings / RCA & line inputs too.
http://mumbai.quikr.com/Escrow/Sony...r-your-home-theater-system-W0QQAdIdZ284664220
Binu
You might need to "UP" your budget to 12 to get anything substantial quality wise.
Dunno about that. call up the seller and see if he can ship it.So it cannot be delivered here in Kolkata ?
Do let us know how it sounds when plugged in. If any tweaks are required, I am sure you will get enough suggestions to get the best out of the system. Good luck.
I am looking for active subwoofer to use with bookshelf speaker, limit is 1 lakh.
will be using only for music, not movies.
please suggest
Whats is the amp you will be pairing this with? With a budget of 1 lakh & its only for music then IMO you should be looking at SVS SB13/16-Ultra Sealed Subwoofer.
Binu AP
LG 42" Plasma | Marantz PM6005 | AJ FS52 | Velodyne Impact 10 | Panasonic dmp bdt220
