Low and high voltage protection
Shivam
Uttarakhand
I am planning to remove the Zephyr power conditioner that I have been using with my system. The power supply is quite clean in my area.
I just need some sort of protection for my equipments from high voltages and brown-outs which might happen. Is there any such thing which just cuts off the power supply outside a range of voltage (say something which cuts off the power outside of 190-230 volts) ?
there are loads of devices for over and undervolatge protection with a ckt breaker and a trip
the best ones are from siemens,ABB and L&T
these are all peace of mind relays
look at the correct ampere rating and buy
a 10 amp rating normally suffices in most high end setups
we dont want to pick a value too high
Can you give me links to some of those devices ?
A V-Guard electronic voltage stabilizer possesses all you have asked for. Low and high voltage cut-offs covered.
I don't want a voltage stablizer. I just need something that cuts off beyond a certain range of voltages. Inside that range I don't want any change in voltage or any kind of correction.
get the monster regernerater then
i think its 100$ but the best reason to buy it is there 1lakh rupee gaurantee
which is to say they insure upto 1 lakh on the system chain connected to them
However their distribution module is crap
if you just require a volatge cutoff as you describe
then just get the L&T relay
man
http://www.larsentoubro.com/lntcorporate/uploads/product/MV12.pdf
indiamart will throw up enough dealers in your area
Why not look at power docs -
I am using it for my house, 3X 16A on each phase of mains after meter.
Su-Kam :: Power Guard 16 AMP - An Aesthetically Designed Nano Stabilizer
And 6A for other places
Su-Kam :: Power Guard 6AMP - An Intelligent Stabilizer
Lower voltage never occurred in my experience but it cuts off at 255-260V mains supply. Also on rainy days, it used to cutoff for few sec while some noise encountered, same time computer ups also made kit kat sound of relay for noise detection.
As an afterthought, I am planning to run my system as a friend of mine does.
I'll use a sine wave inverter and batteries for running the system. Power supply from the grid will be used only the recharge the batteries.
Still to plan the final solution for the power, depending on what system I get after selling of my present AP actives.
Hi shivamji
Where do we install this device?
At the meter room or distribution box at home?
Hi shivamji
I will be using this just before my second system. (I am planning to use the battery option for my main system instead of Zephyr)
It can be installed just after the meter too as per the documentation on their site.
