Yesterday, I pulled the Rethms into the room by 4 feet from the wall behind them. The distance between the speakers and sidewalls was changed to 20". I think more distance from the rear wall will probably make things better, but then I would end up sitting right against the rear wall, which makes things sound a bit off.
I moved the Divan to the side, so that my listening position could mostly remain the same. I'm now sitting 6 feet from the midpoint of the line formed between the speaker baffles now.
This seems to a very sweet spot overall, with the bass sounding just perfect (levels of the subwoofers are at 1 o'clock), with taller and deeper staging, and with everything seeming to have locked in just perfectly. I'll keep things here for a while and do any more moving about only after a month or so, so that I'll be more sensitive to any changes in position. I need to enjoy the music for a while without worrying about any of the "technical" considerations!
