Hi guys,
I've recently purchased the Marantz PM5005 for a simple stereo setup :
Computer > Dac > PM5005 > Wharfy D225.
Absolutely love the warm, smooth sound of the Marantz, especially since I upgraded from a Topaz AM5, which was kinda dry and on the boring side of neutral to my ears. I like to listen at relatively low volume levels. (10 o'clock on the dial).
Now the problem...I feel the Marantz gets a tab bit hot on the top, just above the heat sink even at 10 on the volume dial. It hasn't gone into protection mode or anything, but I'm a bit concerned. So wanted to know from owners of this amp and other Marantz amps (6, 7, 8 series)..is it normal for the amp to get on the 'hotter side of warm' if it makes sense? I would like to add that living in the sultry Mumbai climate with ambient room temps currently in the range of 30-32C doesn't seem to help. The amp sits above an open shelf over my computer desk. Has loads of clearance on all sides.
The temps are well contained when I turn on the AC, but I wonder if that should become a necessity every time I'm in mood for some audio bliss.
One strange thing I noticed. At first, I had connected the amp to an empty socket on my computer's UPS (APC BackUPS BX600C), thinking it'll atleast protect the unit from surge. But after reading up on forums about do's and don'ts with amps in general, it seems connecting the amp to a UPS is a bad idea. Not sure about the reason. Would highly appreciate any explanation/suggestions on this topic.
So I then connected it to a power strip off the wall outlet. I get a feeling that it now gets a tab bit less hot, although it could be a placebo effect. And if I keep it this way, the amp is vulnerable to power fluctuations, if and when that happens.
What can I do ensure a good long life for my PM5005. Would appreciate any stabilizer suggestions as well. The power consumption for this amp is 350w as per the specsheet. I do not intend to add anything else to this setup. This is purely for music listening at close quarters.
Apologies for the long post.
