Pass B1
You will only need 6X Chassis mount RCA,one DPDT toggle and Power switch with fuse all can be had within Rs 250-300.If anyone is for looking good quality Gold plated RCAs from Neutrick can contact Kiran sales Mumbai.It is available at Rs 60/piece Kiran Sales You can order online or personally visit his shop at lamination road.I think Joshua knows this shop.
Sachin
Thanks Sachu! Will take a call based on bibin's info on cost of the same provided by him. Am sure the others will follow suit.
You may require the following items. All the tools mentioned are not required for B1. But they are good to have items for a DIYer.
Please let me know your comments on the below list, so that we can add/remove items and finalize the list of items required for all the members and it will be easy for me to provide the price.
Tools
1. Soldering Iron
a. Goot
b. Soldron
2. Solder
3. Soldering Flux
a. Normal
b. Liquid
4. Wire Stripper
5. Wire Cutter
6. Digital Multimeter
7. Desoldering Pump
8. Tweezer
9. Small Nozzle Plier
Components
10. Nuts and bolts
11. Spacer (SS)
12. RCA Female (Gold Plated)
13. RCA Male (Gold Plated)
14. Power Jack Chassis Mount with 10A Fuse Holder
15. Power cord
16. Two core shield wire
17. Switch - Power
18. Switch - Source selector
Thanks,
Bibin
Thanks Bibin! You may kindly advise cost of Tools & Components separately. Let the others decide whether they want both or only 1 of the 2, based on which you can take a call & we move further with the group buy
Yes DIy Phonostage can be integrated,Omishra,svaze are using DIY CNC Phonostage with B1.
Sachin
Kindly add me for a CNC phonostage to go along with my B1 kit as well,
Thanks!
I will pay you for the same along with the balance owed for the B1 kit. BTW, hope you have recd. the advance in your bank a/c as desired by you.
Thanks!
Done,
I have received advance for B1 .
Sachin
What are the options for an input selector - for say 4 inputs? Is there a ready made switch available that can be bought or do we need to assemble one from components?
You can buy it from Ebay same as Omishra costwould be $18-$25.I am thinking of making Diy input selector board.
Sachin
Please find the price for each components and tools below:
Tools
1. Soldering Iron
  • Goot,Japan (40W) - 400.00 (Limited Stock)
  • Soldron (25W) - 200.00
2. Solder - 110.00 (100 Grams)
3. Soldering Flux
  • Normal - 12.00 (10 Grams)
  • Liquid (Silicon Liquid Flux) - 120.00
4. Wire Stripper - 275.00 (Multitech)
5. Wire Cutter - 100 (Taparia)
6. Digital Multimeter - 165.00 / 600.00
7. Desoldering Pump (Metal) - 190.00
8. Tweezer - 30.00
9. Small Nozzle Plier - 170.00 (Taparia)
Components
10. Nuts and bolts with washer (22mm x 3mm) - 10.00 (12#)
11. Spacer (SS) - 80.00 (10 Nos), Plastic - 10.00 (12#)
12. RCA Female Panel mount (Gold Plated) - 60.00
13. RCA Male (Gold Plated) - 125.00
14. Power Jack Chassis Mount with 10A Fuse Holder - 50.00
15. Power cord - 100.00
16. Two core shield wire (OD 6.5mm) - 90.00/Meter
17. Switch - Power (Push Type) - 25.00
18. Switch - Source selector(Rotary) - 60.00
19. 3mm LED - 10.00 (10#)
Thanks,
Bibin
I ordered following from ebay
2x Audio Knobs Aluminum Black High Quality with shaft for Rs 405
Input / Source Selector DIY Kit (4 to 1 way) 4 Channel Selection for Rs 1525
Santosh
Just a quick question for the experts.....
If we use a 18-0-18V secondary r-core, then what is the DC voltage that we get after the power supply filter?
The source selector kit listed in the link above has specs of 8-15V DC. Was wondering about whether this source selector will work in our B1 kit.
That board has a rectifier circuit build in and it runs on 5v Dc. You can directly connect the 18v AC to that Input selector board.
Thanks,
Bibin
Thanks,
Bibin
Thanks Bibin for your response. Am pasting the specs from the e-bay website
Package Include
1. Input Selector DIY Kit (4 to 1 Way)
2. Rotary Selector
3. Assembly Manual
Features
1. Support 4 single-end inputs (RCA) or 3 single-end inputs plus 1 balanced input (XLR), for both R and L channels .
2. Blue/White LEDs for indicator.
3. Built-in voltage regulator.
4. Required DC supply voltage 8-15V DC.
5. PCB Dimension: 120mm(L) x 53mm(W)
It says required DC supply voltage 8-15 V DC. So can we connect it directly to the 18V AC? Sorry if this question sounds very basic! :o
Package Include
2. Rotary Selector
3. Assembly Manual
Features
There is a circuit diagram provided in the description, check that too. Even if you give 18v DC it will work. If you look closely the board you can see the regulator IC. It will convert the input volt into 5V. Trust me that was not a blind reply, In the diagram you can see 5-30V.
Thanks,
Bibin
Thanks,
Bibin
Thanks Bibin for the clarification. I have always been 'challenged' when it comes to electronics. Trying to break out of it by trying out some DIY!
Thanks to all you guys (Om, Sachin, Bibin and others) for clarifying my basic doubts.
@Bibin - can you please see if you can include tips [chisel, pencil and bent chisel] for the Soldron?
Also,
Soldering Stand with sponge/cellulose
Jackly [or better] 32 in 1 or better screwdriver set
BTW, which DMM are you suggesting?
