Have missed to update my purchases on this thread..
Acquired Taga Harmony Platinum subs from hifimart for 24.5K each...
Got a chinese brand LED projector, UNIC 46 from Amazon.in for 5K
Congrats!
Please post your review of Taga Platinum Subs.
Sent from my MI MAX using Tapatalk
These are few things I Got in last month for Diwali shopping
1. Polk FxiA6 (Surrounds) to replace my 5 yr old Wharfdale WH2 Surrounds , chose white color to be least obtrusive to the eyes of my better half.
They are sounding awesome, the Timber matching makes a appreciable difference, for the movies - good surrounds, almost as capable as you front and center speakers is must. The detailed high freq response of Polks combined with my Denon x2200w makes a lot of difference.
2. Benq HT3050 to replace my Benq HT2050 ,
initially decided to change to LG OLED TV costing 2.5L instead of projector , but after a detailed demo and a very small screen compared to Projector screen - just decided against it. 6-7 yrs with projectors now for HT purposes, it is difficult to go back. Might upgrade to a 4K projector later instead.
HT 3050 is awesome, the preset Cinema 709 mode is wonderful, Just Plug and Play No tinkering needed; great DLP projector , which I'd recommend to anyone.
3. after much researching and demoing on Stereo Amps( budget around 30k) ,This 10yr old Onkyo Integra costing nearly half made a Lot of Difference. My Polk RTI A5s just seemed like they came to Life, Everything the Low freq, Vocals , Strings sound much better Now. Looking for good DAC to complement this analog stereo amp now (budget around 30k).
Nope.. Just saw screen types, this came up on the search.. picked it...
Any better ones for the same price?
Ok, on Amazon inlight map has more reviews and popular. I think I got mine simple hanging screen from him through ebay, replies to all queries as well.
Sent from my XT1562 using Tapatalk
Congratulation elangoas !
Waiting for screen shoots ...at the earliest please !
Thx skdas..Awaiting PJ screen to be delivered..Sure will post..
Thanks for the product..8 x 6 feet Map type of inlight is 3K.. I got Luzon Dzire 8 x 6 feet pull down for 3.5K.. Not sure if it is really worth it..
Should get to know soon...
Congrats...curious to know feedback on projector and the screen!
Hi all
New to this forum. I just purchased pioneer vsx930 K from Kuala Lumpur, approx 35k. Customs said no duty required for items under 50k at Chennai airport. Need to start buying speakers now :)
This is last year model 2015 but I chose this over yamaha rx-v481 because this had 4k upscale and atmos support at a slightly higher price 5k more. The equivalent yamaha model is 681 costing another 5k more though it's this year model with dts X support. For the price point pioneer fit best.
Bounce has proved to be a failure in most house conditions. I doubt it would be of any effect.
