just4kix
Look at the ST30 thread.Had a question, how to find out TV running hours.
I was also in search of both Models in Chennai, even the panasonic brandshops do not have these models till now!
I was really frustrated. however if you would be interested in a group buy , other like Arun, mylgcookie we could negotiate the prices.. Please send me PM
I decided to wait for the Panasonic installation guy and get the details.
I wanted to know what is the acceptable running time and count, should it be zero or there will be some time (usually when its tested in the factory)?
What is the care I need to take for first 200 hrs.
39 minutes with 4 times switched on - but that was after some initial testing. Check first few posts.thanks just4kix, I will follow your mentioned steps and check again. btw, how much was your running time when you had purchased it
Got the 50ST50 TV yesterday. followed the points mentioned to verify if it was demo piece. The box tape was intact. However, the way box is opened, is that it has plastic type locks in the slots at the lower end. Once its removed, the upper part of the package can be removed. In this case even if the dealer doesn't cut the upper tape, he can still open the box.
I checked for any fingerprints on the screen, couldn't find anything. However, I noticed slight dusty area at the back. I was wondering if it's a new piece, there shouldn't be any dust if its factory packed. I am now slightly confused if it's a demo piece.
I tried to verify the running hours as mentioned in ST30 thread but somehow I couldn't get it looks like I was missing something. I decided to wait for the Panasonic installation guy and get the details.
Any inputs are highly appreciated.
* Hold down the {VOL -} button ON THE PLASMA.
* Press the {INFO} button on the remote control 3 times.
* The Service Menu will be displayed with the following menus:
o ADJUST
o WD-ADJUST
o OPTION
o AGING (Red Screen)
o RM-SET
o SRV-TOOL
The {1} & {2} buttons move through menus (up/down).
* Press the {2} button once or
press the {1} button six times to select "SRV-TOOL".
* Then press the {OK} button to access it.
* Using the cursor keys, * highlight * the empty
right side of the last option: PTCT :00.00.00.00.00
| TD2Microde: 81c0000f |
| Flash ROM: 1 - 227 e |
| PTCT :00.00.00.00.00 | * HIGHLIGHT HERE *
* Then press and hold the {MUTE} button for 3 seconds.
* Time and Count will be displayed in red color.
TIME = Hours and minutes of operation.
COUNT = Times the Plasma was powered on.
* To exit, press and hold the {POWER} button
on the Plasma for few seconds.
	Another advice, get the break in slides (solid colors) and check for dead pixels. My first set had a couple of dead pixels.
Thankfully the 2nd set had no such issues.
	Found in another forum. ST50 tops in all. Value,feature, picture quality and design.
