This month, the consumption was 120 units.Plasma TV and the high power consumption argument
It has been often argued over threads that:
- Plasma TV will bloat your power bill. Sensationalist claims were/are as high as "at least twice" your existing units.
- TV will heat up your room. Once again some people (like typical doomsday predictors) said that you will end up sitting in a furnace.
- Because of heat, you will end up using AC more often and further adding to the power bill.
I have been carefully monitoring my power consumption since the day the plasma TV was purchased and installed. The TV usage started from 25-July-2012. The power usage pattern has been very revealing. But here is an actual download from the MAHADISCOM website (power distribution company in MH state):
A careful analysis shows the following:
So much for the "high power usage" and "not going green" outcry.
- The 50" plasma TV replaced the 21" CRT.
- Power consumption has more or less remained the same during the same period over the last year; actually, in fact it reduced a little by some 20 units.
- While the TV does generate some heat, it is not enough to cook rice. Heat (lukewarm) is felt only when standing 6" close to the TV.
- During the last five months or so, there was not a single day when AC was required. It will be required in Summer but for entirely different reason.
 hyeah: Movies are excellent on this TV as it is explained before. Deep black levels blah blah... Its all there what has been explained previously on all the reviews. Manufacturing date Sept 2012!! My frnds still cant believe cos I got it for such a less price!!
As a 50GT50 owner. The Power consumption from a plasma is variable from as low as 90W to 350W depending on the brightness of the content and calibration settings (more for dynamic and less for standard with lowered brightness). Mine hovers around 150W in THX cinema mode with Eco activated and 200-250W with Eco mode deactivated.
My plasma is connected to a APC 1200VA UPS which gives real time power usage.
Vakharia your location please?
I own Panasonic P50ST30D tv... and WDTV Live media player
wanted to buy 3TB external HDD for movies... will it compatible with this TV?
If you read/remember my first few review posts, I have said that HDD reading by the TV is very slow. It takes almost 10+ minutes to read my 2tb hdd. Everyone you switch back from media player to standard TV and back to media, it goes thru the 10+ minute cycle. It does not mater whether the hdd contains just one file or hundreds. You are better off with a media player or BDP.
Sent from my GT-I9100G using Tapatalk 2
As far as I know, this is not true. But I could be wrong. Anyway, it is better to have a small size HDD connected directly to TV because TV takes a very long time to read the HDD. Read my first few posts in this thread.just4kix thx...
read somewhere on the net that you have to 1st create 1.5TB partitions then only TV can read only 1 partition. Is it true?
I am surprised and happy for you. In my case, the TV takes a very long time to read the HDD. I tried many options:Bought 2tb expansion hdd yesterday....... Copied movies abt 20gb and hook to the tv.
Viola... Tv detected and read in 20 seconds..... Movies are played with ease.. No problem at all
- removed all content other than movies from HDD
- put movies in root directory
- moved movies into separate folders
- added back all files and documents removed in step 1
The TV took the same time to read. As I deduced, the TV tries to read each and every file and checks whether it is media file and then after scanning thru the entire set of files, displays all the "playable" files. The TV displays all the files in a sequence and not by folder.
Perhaps, my firmware is old.
