Hi Friends,
Finally I unpacked the BIC America F-12 (230 V AC 50 Hz) and did initial setup for testing purpose. I couldn't give the needed time for proper setup due to busy schedule.
I placed the sub in the corner under the dining table(don't know placing it under the table is OK or not). Ran the YPAO setup two times and received W-3 error both the times. It still needs to be diagnosed what W-3 error is. Kindly help for this W-3 error.
Then I did manual setup.
Sub Volume at 4.
Sub Crossover set to full 180Hz.
Sub Phase set to 0 degress
Receiver Type set to Digital 5.1
In AVR I did following settings :
All speakers set to Small
Crossover set to 60 Hz
Sub Level set to 0 dB
Played few songs and few movie scenes and window glasses started to vibrate. This sub is very powerful. I turned the Sub Volume to 2 to control the vibrations.
First impression in a single line - "I have now a beast at home that can shake the walls and needs to be tamed."
I need to spend more time for best setup. Different Sub placement. Different Volume Levels. Different crossover settings.
Few pictures of the sub are attached
Will come up with more details and request you all to guide me about W-3 Error.
