Buck of useless features that provide no joy beyond initial fascination. Check PQ and go for the TV with better PQ.
hmmm..
but even in PQ I was reading other threads and seems F6400 is better than W800 / W804A ?
Can u check..
Only last year's LED models of 55" wide are available at around 1 to 1.2 lacs. If you are ok, then you may scout for one. LG6700, Pana 55ET5D etc
With your budget you should look for sony46W950 which is superior picture quality.Usually superior pq models will have 3d, wifi and every all other added facilities.if you insists on 55 incher, you should raise ur budget.
Yes. model year is not the problem. Only thing I look for is 55", PQ. I'm not bothered about other features. How about the PQ of LG6700 and Pana55ET5d?
I have been going to different outlets and comparing Led's exhaustively mostly from Sam and sony.
and yesterday i shortlisted these and going to Buy XXXX (lol read till the end and you'll find out)
1. r422a - 30k
Specs say there is no picture processing engine ? i dont know what that means ?
2. EX330(2012 model) - bravia 3 engine - 30k
3. W600a - wxga, XREALITY PRO , internet - 38K
4. EX550(2012 model) - XREALITY, internet - 36.5K
5. SAMSUNG F5100 - Full HD, HYPERREAL ENGINE - 36.5k
6. W650a - Full HD, X-REALITY PRO, Internet - 42K
My analysis
R422, w600 & 650a have no difference. 650a being just a little brighter than R422.But comparing 650 and 600 there is absolutely no difference no matter what you play(HD or SD or bluray).
EX550 vs 600a - 550 was more bright.i was surprised since it is a 2012 model with X-REALITY engine and 600a comes with X-reality pro.I was wondering as to what justice did the "PRO" did to 600a ?
F5100 vs W650a - Now here the difference can be clearly seen in colors. 650a clearly had more natural colors.F5100 was good but skin colors did not felt as natural as of 650a.But you would only notice this difference if you compare side by side.Honestly its a trick that your mind plays lol.If you turn off either of them then it would be just as good as the other.The difference is not worth the price difference of 7K.To make things even i would say that F5100 had warmer colors and 650a had softer colors.
Ex330 vs R422a - ex330 seemed dull but crispier and sharp than 422a even though it has bravia 3 engine.But since they are the same price and R422 is newer model i would say go for R422a
So my verdict is that if you want Full HD only and want to spend not more than 36K then go for Samsung F5100.
If you want an internet TV + Full Hd - 650a
If you only want internet only and Full Hd does not matter and believe me for 32" it doesnt then go for - W600a
But if you are willing to settle for Hd ready cheap and almost equal in quality to 650a then go for R422a.It does have slightly less brightness than W600a.By slightly i mean less than pinch of salt lol.
Now between Ex550 and 600a i would prefer 600a because i really believe in sony and i feel that maybe Xreality pro is same as X reality and maybe Pro kicks in at specific scenes and lighting.Since price difference is only 1.5-2K or maybe even less you can consider 600a.
Overall W600a is best 32" HD Ready under 38K.
Samsung F5100 - best FullHD led under 36K.But for Full Hd you have to trade of softer colors of W600a.
R422a - best Hd ready Led for 29K.
Now this doesn't solve the question of whether difference is worth spending more.But i think it depends what our eyes like.If we are happy with warmer colors of sam F5100 then it really doesn't matter because wet Full HD.If we are happy with slightly less brightness of R422a ( almost unnoticeable if you compare them one at a time) than the w600a then we can buy R422a.Personally i dont see any reason to buy w650a.I did considered W600a but then i realized that i watch Tv mostly with light off so whatever slight difference R422 has in brightness would be compensated in the darkness of the room.Also i dont need internet too.So finally Im going for R422a.If not R422 then i would have gone for W600a but never for 650a as it is really not worth it.
1. r422a - 30k
My analysis
