Hi Guys,
I recently bought a Yamaha 3900 for my games/theatre room and having a few issues getting any output from my sub.
I have only been using 2 front speakers plus the sub so a 2.1 set-up. From default (or initial set up) I have output from my sub and missing various other audio outputs I assume because probably defaults to a 5.1 or 7.1 setting?? I then plug in the microphone and it does it's sound check. After this the sound is fine from the 2 front speakers ie. getting all audio, but the sub is then inactive.
I then go through all of the audio settings (or program functions) that change all the different types of outputs and I can select 7 channel or 2 channel and then all the other variations but it doesn't seem to make any difference to the sub.
My previous av receiver had a 2.1 setting and that is what I used but this just has 2 channel stereo.
The sub is connected fine, as I said from initial setting (after resetting) there is output from the sub but not all audio is being outputted to the front speakers.
Does anyone have any suggestions or what I'm doing wrong here? I have been through the manual numerous times and can't find anything to help.
I also really only want 2.1 as I play a lot of music and watch alot of music dvds. My seating is also in the middle of the room so don't really care for the surround effects of a 5.1 or 7.1 setup.
I love all this audio / hifi gear but man I hate setting it up and especially when I can't get it to do what I want.
Thanks for any help / suggestions!!!
Mark.
Mark.
