Hello all,
I am trying to self assemble a smart TV.
I need few inputs for doing so from this amazing community.
ill explain my setup.
1) I have already purchased AOC 27 Inch IPS monitor having 2 HDMI inputs and inbuilt speakers which are very bleak.(reason for going for AVR)
aoc 27inch ips monitor
2) YAMAHA 196 AVR for alternate sound as monitor speakers are too weak.
3) an android set top box running android 4.2 with quad core cpu that has an hdmi out and also optical cable out.
alternate one
alternate two
alternate three
(If some suggestions can be given in choosing these alternates that would be helpful too.)
I will give input from the TATA SKY stb to avr + android STB to avr and connect TV to AVR through hdmi cable using YAMAHA's HDMI out.(This should definitely work right? any issues i could be involved into?)
as i dont plan to buy or use BDs discs , so the issue being discussed in this thread seems irrelevant in my case as the TATA sky stb will obviously do the job of decoding all the hd channels audio and send through the HDMI,(also i dont expect any of the HD channels to broadcast DD HD or DD THD), so i am covered in that part.(right?)
Apart from that, android stb with MXplayer will decode all the audio and send it to avr so i am covered in that part aswell.. i am not sure if mxplayer now supports DD HD or THD decoding , or if say in future if it does support it, i think ill be covered in that case as well as all the decoding will be done either by MXPlayer software (in s/w or h/w mode).
(which port on android stb would give best sound? HDMI or Optical Audio out available in one of the android stb i just reffered)
I am verymuch sure the content i am interested in (which exclude dvd/bd playback) will work in my current setup..
Can the community here help me in finalizing if this setup is going to work for sure for the usecases that i have mentioned here.
I will be greatefull for this help just before i go for this yamaha purchase along with the android stb.
Thanks all.
