hardcore_gamer99
11x11 tv sony oled 65Congratulations!!!
What is your room size?
What size TV?
What size TV?
Pc wont play 4k i have lg wh16ns60 4k intrrnal drive but powerdvd gives intel sgx errorWow! Enjoy!! I want those ub820...how much are those?
Cant we use a pc with blu ray drive?
How is it different from pc?
Reduce the volume or channel levelsDAMN THESE DALI OPTICON MK2 MY TINITTUS GOT WORSE IN RIGHT EAR. I PLAYED SPECTRE OPENIBG SCREEN IN 4K HDR IT WAS BOOM I MEAN BOOMER I DONT need A SUBWOOFER LOL WILL POST VIDEO TOMORROW
It was painful task as i was doing everything firdt time. When first connected only wires on back of avr but not on actual equipments denon gave humming noise. In the end belkin hdmi which was in bluray slot was culprit. Returning it tomorrow. Also till 70 voluke on avr colume is too lesss why so? But above 75 it gives sound like a theatre thunder.Reduce the volume or channel levels
Volume setting is there in avr.where you need to put teference level at 0. By tomorriw i will provide the navigation which i used with maranz 50.It was painful task as i was doing everything firdt time. When first connected only wires on back of avr but not on actual equipments denon gave humming noise. In the end belkin hdmi which was in bluray slot was culprit. Returning it tomorrow. Also till 70 voluke on avr colume is too lesss why so? But above 75 it gives sound like a theatre thunder.
is there any run in period? what do u suggest?Dont listen that much louder. My self general listening volume is 50.
Guess you are satisfied with mid bass and the room accoustic is boosting it more. Subwoofer is something more felt than heard. Thats when the seat (the foam shakes the body)...got some songs that do that...better save your bank and dont let yourself in this teritoryDAMN THESE DALI OPTICON MK2 MY TINITTUS GOT WORSE IN RIGHT EAR. I PLAYED SPECTRE OPENING SCene IN 4K HDR IT WAS BOOM I MEAN BOOMER I DONT need A SUBWOOFER LOL WILL POST VIDEO TOMORROW
no room acoustic done and will add sub soon. can you tell why they feel low volume below 75 and aabove 80 it sounds like a theatre. did audessey setup did some thing wrong/Guess you are satisfied with mid bass and the room accoustic is boosting it more. Subwoofer is something more felt than heard. Thats when the seat (the foam shakes the body)...got some songs that do that...better save your bank and dont let yourself in this teritory![]()
got it for 60000 but it is region b lockedWow! Enjoy!! I want those ub820...how much are those?
I never liked dynamic eq on....better left offEnable Dynamic Eq and listen at Low volume.
In general my listening volume is between -25 to -22.
Some times for music -34.
As yours is also non accoustically treaed room dont put high volumes like 75.
As op has some issue in ears suggested to on dynamic eq.so that ears wont get stressedI never liked dynamic eq on....better left off
I think you are using 4800 you may help him.As op has some issue in ears suggested to on dynamic eq.so that ears wont get stressed
will share in evening and will play some 4k disks as wellCongratulations. Do Pl share some pictures after setup is completed
