new subwoofer help
Did sub crawl again today and put chair my hand is paining but when i put the sub actual position its same bass is less. Tried phase as well 45degree did a bit bit not same as it was on chair. I ahave given up now....
i have finally given up on this subwoofer did crawl today 4th time and put here but again when it was on chair and i was on floor bass was deep but actually its all same not that good brah...
You need to run it for at while to burn in.
ok i have reset my sony oled and denon as well . i am not touching any setting now will do crawl again today for subwoofer and this will be my last crawl. i will then use REW software with umik1 mic which arrives tomorrow. can you confirm if rew can give best subwoofer sound?
Haven't used REW, but it improves the calibration as per most forum members
Search youttube for 80hz. Keep front speakers to full range then subwoofer lfe+main and subwoofer crossover to 100hz and then try
I played a song these are sound metre results on all phases
