new subwoofer help
See post No. 365 above.
You have not read the Audyssey link I have posted in #364. Please read Audyssey 101 linked below completely.
https://ask.audyssey.com/hc/en-us/sections/202387323-Audyssey-101
what is this? will it help in deep bass
Before buying expensive panels, just try with stuff you have at home like pillows or cushions. I have basotect g+ but honestly it’s overpriced for what it does. Anyway before going with something like that, try with something you have at home to see if it’s improving. My relatively large floorstanders had this „hole“ which sounded really bad. Without the panels bass was virtually „phased out“ and boomy
Where do i put pillow?
HOpefully denon performs so. But when audysy is set to reference the amp denies to pump out lows. The polk r700 bass driver dont move much and there is no punch. Thats how i derived at it.
Lets see if what you suggest brings bass to hardcore gamer here and may be i will learn something new!
And I had already mentioned about setting phase in svs app to 0, 45, 90, 135 ....
Without full range front speaker setting denon wont give those thumps out- neither to the fronts nor to the subs. TRY!
And by the way do you have the option in menu to set speakers as 'large' or 'small'? Which denon/marantz model currently un use?
now do you want me to adjust phase with front as full range and lfe+mains? or something else
upgrading slowly. i will add atmos and back surround pair as well
When you have audissy is there which is free and even audissy app which is at minimum cost why we need dirac which is nearly 50k. And it is device specific . Instead you can buy a center and hive some amount for a technical person for calibration .
