Thanks Srini. Yes it is indeed around 6/7 feet distance, my room is 100 sq ft. The floor standers are a bit overpowering for the room, but with the placement of the sub on the right side that's improved a lot.previously they were next to the right speaker
Mind you this is only for 5.1.. for music i have the bookshelfs.
And no treatment so far for the room.
Yep thanks Sachin for posting your real time experience. Have you tested without sub, how you felt the bass(leave the lower freq)
Hi Srini. if your question is if i can do without a sub, no:) actually i had only the 2 floorstanders initially and slowly i upgraded with the sub and the surrounds. It is does give the punch which the floortanders alone cannot.
Hi reignofchaos
We can make the blue light dimmer by 3 steps and switch off completely using the remote control.
Anil.
Hi all,
By [URL=http://profile.imageshack.us/user/sachu888]sachu888 at 2011-10-20[/URL]
Technics SlD-303
Technics Su8022
Micro Seiki MB14st
DIY CNC phonostage
Musical instruments
Sachin
Technics (Matsushita Group) use to make some of the best Audio Equipment but its sad that they dont make much now.....8-((
Dont sale those Technics , you wont get it anymore .......
I won't sale my amp,but TT might be for sale due to space.
Sachin
