Pansonic XT50 owners thread
Re: backlight bleeding on plasma>
Why the hell I did not buy VT20...Man this is stunner,,,,,,,,,,,,:-(
B450 vs VT20 Blacks | Flickr - Photo Sharing!
The above compares the reflectivity and black level with my earlier samsung plasma.. The XT50 will more or less lok like that since it does not have the infinite black pro filter. The VT20 has 0 reflection in the daytime as you can see.. :)
Should I be worried? I off-course understand it cannot match V series tanks to lack of Pro filter....
Still from XT 50 perspective...
The screen should not be uneven. Iam not sure of the light emittng since I never saw a lower panasonic in the dark to compare. But it looks worser than my samsung plasma..
B450_Dark | Flickr - Photo Sharing!
That too had(has) a perfectly even screen.. Check above foto..
I did..However, night mode looks better...However, Indoor mode images may be due to camera...
Also, just to share that First image which I had shared 2 days back was not of my plasma,,
Your screen is uneven and seems extra wheatish.. I would check with the panasonic technician.
The fotos should have perfect back 'around' the TV to compare. You mobile fotos show area covering the TV also as non black. Not the ideal fotos to come to a conclusion.
Your screen is uneven and seems extra wheatish.. Could you please share which image
I am bad with images,,,
@Pralhads
If you haven't checked out plasma in home condition, you can visit my place dude.. You will realize why I say 50" is better and 3D is shit..
Sure Blasto.
Thanks for invitation.
Lets see when can it will be worked out.
I will try to get metro contact and update.
I created a BLACK image and took pics..
Here is an album....This look bad..I have included the image used for display purpose as well..
ImageShack Album - 6 images
this looks similar to what I have...the whiteness or blackness depending on how you see it looks uniform across the screen and this is not radiating light like the sun....am i missing anything?
Issue Details with images: Details with images are produced below:
1. Green-Pink Vertical Lines : The green-pink lines are visible all across the panel. I have clicked images for your ready reference.
In the suggested case, I am experiencing multiple vertical & horizontal lines. Historically, Panasonic has replaced sets even if users experienced even single green line.
http://img155.imageshack.us/img155/6650/photo0422b.jpg
http://img560.imageshack.us/img560/1438/photo0413r.jpg ( USB Mode)
http://img189.imageshack.us/img189/1340/photo0425b.jpg ( USB Mode)
2. Uneven Brightness : Screen has uneven brightness, which is reflected clearly by attached pictures. Pictures are taken in an absolute dark room, with no ambiance light.
http://img842.imageshack.us/img842/3176/photo0379e.jpg
http://img850.imageshack.us/img850/2799/indoor2.jpg
http://img839.imageshack.us/img839/5091/photo0377o.jpg
3. Cannot display BLACK: Possibly related to above brightness
I used a black slide for display. Please see the result. My acer notebook with far cheaper screen showed it as dark black.
http://img215.imageshack.us/img215/7362/blackscreen2.jpgm - 2 images[/url]
Why posting same thing @ 5 different threads bro - save us the horror...:cool:
Its posted only in 3 threads..All panasonic owners thread...
Also, this is not to raise any voice as I have got feedback from Blasto suggesting these are issues.
Wont it be good to update users about this? Specially potential buyers...
If this is horror, ...guess there are better words to put across the message,,,look at my id for an example...lol
I agree its correct to update many people about the issue. And as long as he is alerting through relevant threads, its okay i think.
Is this specific to XT or even X is giving the same issue ? any feedback on X50 ? (I am contemplating buying either E470 or X50 hence asking).
3d in XT50 is not bad...Its +1 to 2012 range
@Pralhads
I agree that 50 Inch without glasses at 50k is a sweet deal..however, let me tell you 3D is awesome in this plasma,..
My bro got ST30 & LW5700....This one is suprior than both...Glasses are so light..
Also I changed my settings so ZERO Flicker even when I sit directly under light.....
I too agree that 3D is cool for its gimmicky value and in a family with kids -thats fun. I dont see any big lines like ur picture shows..how wide is this line? 1mm or 1 cm?
These are thin lines mostly....I have played zoom mode in camera while clicking
May I request you to please check:
1. Go to USB mode using media player button and observe closely if you see lines like I have reported above??
2. Put a black color wall paper in USB and click an image in Dark room..
If you have break in slides, you would be shocked to see there are lines all over the panel...
I can press for a replacement if this is a defect...Hmm 50K and all these :-(...
all fun is gone :-(
If you wanted him to response to your query, you could have directly asked... no reason to butter him that he is alerting many people and all that... all the threads are seen by same people...:yahoo:
